Home > Technical > 2008 RRS TDV8 Will not start....with a twist! |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
all that flashing and clicking points to a battery issue. the fact that you've only had the alternator and battery for half a year point to a drain issue, in other words something is maybe draining the battery when the car is off.
Mon Nov 23 2015 10:27am |
I would check battery terminals to see if they are tight, then check alternator, to see if everything is connected as it should be. Also check connections on the starter motor. Those would be my first 3 items to check. Thirdly, join a breakdown recovery company. A must if you own a RRS. |
Mon Nov 23 2015 3:27pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
Good luck checking the connection on the alternator. Takes a bit of digging to get to. 2012 SDV6 - it's missing a couple of cylinders
Mon Nov 23 2015 7:17pm |
