Home > General > Woke up this morning half asleep...
...to find my battery in a heap.
Not enough to turn the starter motor, just a machine gun rattle from the solenoid. Jump started the "premium" RRS from the ever-dependable, butt-of-many-jokes Skoda. Ran the engine for a couple of hours which included my normal commute and the battery has been ok today. Dropped in to my usual indie on the way home and they have confirmed what I suspected - the alternator is on its way out. Would produce 14.5V when revved but at idle it was showing 12.2V! Also, the generator demand didn't change from 65% even with both screen heaters, seat heaters, lights and fan all on. It's booked in for a new alternator on Monday. Currently sat on the drive with the Ctek plugged in to the tow socket to try to keep the battery happy 'til Monday. Luckily I don't need it too much before then.
I bought a new battery (Yuasa HB019 100Ah, 900A) from Halfords this morning because I needed to use the car during the day and didn't want to be stranded. I remembered to chuck a handful of sockets and spanners in the boot before I left home, just in case.
As I didn't need the new battery today, I shall fit it on Monday after the alternator has been done. No point keeping the 4 year old battery in the car after it's been totally drained.
During the diagnosis, the chap said "sounds like you have a cylinder down". No good asking me as my ears are Censored although the hearing aid helps. Looked at the balancing offset thingies and number 8 injector is at about 1350 with the others all at about 950. Not sure what these numbers refer to but it was obvious that one was very different. Will be interesting to see if the engine feels any different after its changed.
Looks like Monday is going to be expensive - a new injector is more expensive than an alternator!
I wouldn't mind so much if I didn't actually try to mitigate these things. I check the battery voltage regularly (a week ago it was 12.7V after being sat for 12 hours which shows how quickly these things go when they go) and give it a Ctek now and then. Looks like the alternators that LR use are just made of cheese as this one is only 4 years old!
What is odd is that my BAS FBH controller ran as usual this morning to heat the car; if the battery was that bad I'd have expected the FBH to refuse to start up. Can't believe it would cause a massive battery drain. 2012 SDV6 - it's missing a couple of cylinders
Post #480408 Thu Nov 19 2015 6:35pm
Tim in Scotland
At least you know now that come the first deep frosty morning when you need the seat heater, heated steering wheel and front and rear heated screens on that they will not kill the car now! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #480444 Thu Nov 19 2015 10:13pm
I hope so anyway... 2012 SDV6 - it's missing a couple of cylinders
Post #480453 Fri Nov 20 2015 12:50am
Lost for Words
Re: Woke up this morning half asleep...
Keep your fingers crossed that you don't need all eight! The one with the high value is not always at fault, hence once replaced, the value can move, even to the extent that they all need changing (and we 6-pot owners though we had it bad!). Mad With the only one reading high, it will hopefully just the one though. Thumbs Up
IIRC the standard cut off voltage for the FBH is only 9.5 (or was it 9.7?)! Visiting from DISCO3.CO.UK
Post #480467 Fri Nov 20 2015 9:06am
Thanks Lost, I was feeling OK until you threatened me me with £2400 of injectors... Big Cry 2012 SDV6 - it's missing a couple of cylinders
Post #480538 Fri Nov 20 2015 8:54pm
Lost for Words
I know, I know. Embarassed
Better pre-warned at least, and it's only a possibility. With one bad reading, I don't think it's that likely. Thumbs Up Visiting from DISCO3.CO.UK
Post #480564 Sat Nov 21 2015 9:11am
Fortunate its not a 5.0L S/C set of 8 with vat. £5375.00 retail Rolling with laughter
Post #480565 Sat Nov 21 2015 9:42am
Had the battery on the Ctek yesterday. Went out this morning and the battery was showing 12.55V. Tried to start the FBH with the remote and it refused. Checked the battery again and it was now down to 11.8V. Should still be enough. Put the key in and turned it but didn't try to start the engine. Battery now showing 8.4V! Safe to say the battery appears to have a couple of cells that have died. Will be changing the battery to enable me to drive to the garage on Monday after all. Glad I bought the battery already... 2012 SDV6 - it's missing a couple of cylinders
Post #480576 Sat Nov 21 2015 11:36am
Lost for Words
I think Robbie may have just mentioned your exact issue:
Robbie wrote:
A rather common occurrence is a leakage to ground somewhere on the vehicle, with the alternator diode pack an all-too-frequent miscreant. Whilst it may seem a trivial number a ground raised to around +0.27v is enough to prevent the FBH fuel pump from working.
Post #480578 Sat Nov 21 2015 12:07pm
Robbie
Location: Waiting for my old avatar to be allowed back... we miss her!
Hello! Land Rover - Turning Drivers into Mechanics Since 1948
How To - Battery & Quiescent Current Drain Testing
Free Fault Code Reading For Established Members:
Defender, FL2, D3, D4, Evoque, RRS & FFRR
Post #480582 Sat Nov 21 2015 12:31pm
What is odd is that the FBH had worked on the morning that the car refused to start. I'm hoping it's all just the alternator; could do without having to chase an electrical issue as well.
Fingers crossed it's all sorted on Monday. Thumbs Up
Hi Robbie! Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #480584 Sat Nov 21 2015 1:14pm
Lost for Words
Yes, I'm thinking it's down to the alternator. Thumbs Up Visiting from DISCO3.CO.UK
Post #480585 Sat Nov 21 2015 1:26pm
Changed the battery. What a faff that was! Should be a simple plug and play job. But turns out the bottom of the battery box has a lip that projects over the base of the battery. This is fine in LR batteries but the Yuasa one from Halfords? Nope. Just needed 15mm of one end cutting off the lip in order to pass a slightly thickened section on the battery's base. Not difficult but lifting the battery in and out twice was annoying.
Decided to plug the Ctek in to the tow socket until I start it tomorrow morning. If there is a parasitic drain somewhere from the alternator, hopefully this will stop the battery being flattened overnight. 2012 SDV6 - it's missing a couple of cylinders
Post #480651 Sun Nov 22 2015 1:21pm
Jaggs
Where can you get the ctek towing plug adaptor, have a charger but the adaptor would be ideal
Post #480656 Sun Nov 22 2015 2:09pm
Search Ctek in Forum Shop.
Post #480657 Sun Nov 22 2015 2:12pm
