Home > Maintenance & Modifications > Exhaust mod ideas please
gangnam007
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
I've got a range rover sport supercharge and want to do a mod on the exhaust to make it sound like the Range rover sir
Post #479954 Sun Nov 15 2015 9:58pm
You don't have to call me Sir, even though others around here do Smile Laughing
One assumes you meant SVR?
I guess your best bet would be to find a local exhaust firm that can fabricate something. I'm sure some of the bigger names have offerings, but you'd probably get better results with something bespoke, and probably not as expensive either. Smile ON THE WAY: BMW F21 M140i
Post #479975 Mon Nov 16 2015 7:29am
gangnam007
Hi sir yes I meant svr lol
I was told by John Ashley exhaust in Walsall that they would advise decat the car
Post #479978 Mon Nov 16 2015 8:27am
Paddi
Try giving Powerspeed in Asford Kent a call. Easy trip down the M2 from London.
http://www.powerspeed.co.uk/
Not had my RRS modified by them but they did a cracking job on my 911 catalytic converter a few weeks back. Sliced it open, removed the old crudded up 400 cell cats, inserted 200 cell cats and TIG welded it back together so beautifully you'd never know it had been touched. Another 11-15 BHP and a nice bark and crackle on the overrun.
Very very much less expensive than some other specialists quoted and all done while I waited and watched with a mug of tea. Don't expect any fancy showroom nonsense or bimbos tottering about on 6 inch heels though!
Powerspeed can make up any sort of exhaust you want or modify yours. They are quite happy to do a group discount if you get a few other RRS owners to join you. I'll probably get them to do a back boxes delete and chrome exhaust tips on the RRS one day but have a few other things to sort out first. 2008 MY Java Black TDV8 HSE
Post #480015 Mon Nov 16 2015 4:07pm
gangnam007
well i just visited john ashley exhausts in walsall yesterday and they said that doing a straight pipe might help - has anyone installed a straight pipe or x pipe on there car?
Post #480200 Tue Nov 17 2015 10:09pm
TheWojtek
I have replaced the big muffler under the car with an X-pipe. The car is only marginally louder, however it takes a lot of effort in sport mode to make it crackle and bang like the SVR does. And it only happens on downshifts, since the engine ECU is not pre-programmed to momentarily overfuel on upshifts like in the SVR. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #480242 Wed Nov 18 2015 10:15am
gangnam007
so is yours a supercharged version also?
I don't know what to do then as i want to make it louder but looking at your last post it seems there isn't very much we can do
Post #480481 Fri Nov 20 2015 10:55am
Camelrock
I'm sure the boys above who'll decate your car will make it fail an MOT unless there just going to remove the guts and leave the cans ? 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #480503 Fri Nov 20 2015 1:19pm
TheWojtek
Yes, an SC.
IMO to make it more SVR-like you'd have to remove the catalytic converters and all but the rear silencers and overfuel the car a bit (which means: a custom tune should be able to do the job). X-pipe instead of the center muffler frees up more of the V8 "burp". Regards etc.,
Wojtek
Post #480573 Sat Nov 21 2015 11:09am
gangnam007
ok so the sounds of things we won't be able to replicate a svr lol
but whats the best option to open up that v8 noise? should i change the exhaust box or the centre box? if i replace the centre box with a x pipe would it not use more fuel?
Post #480617 Sat Nov 21 2015 10:24pm
TheWojtek
I have replaced the centre section with a X-pipe and I haven't noticed the car to use any more fuel than the obscene amount it does anyway. Regards etc.,
Wojtek
Post #480634 Sun Nov 22 2015 9:28am
gangnam007
whats the sound like with the x pipe on? have you got any videos? does yours still have the original back boxes?
Post #480707 Sun Nov 22 2015 9:34pm
TheWojtek
I will record you a clip. Regards etc.,
Wojtek
Post #480732 Mon Nov 23 2015 10:59am
gangnam007
did you manage to record a clip
Post #480848 Wed Nov 25 2015 12:25am
TheWojtek
Hi, I hadn't had time before and had to ask my 6-years-old to record it using the phone, lol. Anyway, here you go.
 Regards etc.,
Wojtek
Post #481104 Sat Nov 28 2015 2:19pm
