Home > Maintenance & Modifications > Exhaust mod ideas please |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
You don't have to call me Sir, even though others around here do
Mon Nov 16 2015 7:29am |
gangnam007 Member Since: 17 May 2015 Location: london Posts: 49 |
Hi sir yes I meant svr lol
Mon Nov 16 2015 8:27am |
Try giving Powerspeed in Asford Kent a call. Easy trip down the M2 from London.
Mon Nov 16 2015 4:07pm |
well i just visited john ashley exhausts in walsall yesterday and they said that doing a straight pipe might help - has anyone installed a straight pipe or x pipe on there car? |
Tue Nov 17 2015 10:09pm |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
I have replaced the big muffler under the car with an X-pipe. The car is only marginally louder, however it takes a lot of effort in sport mode to make it crackle and bang like the SVR does. And it only happens on downshifts, since the engine ECU is not pre-programmed to momentarily overfuel on upshifts like in the SVR. Regards etc.,
Wed Nov 18 2015 10:15am |
so is yours a supercharged version also?
Fri Nov 20 2015 10:55am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
I'm sure the boys above who'll decate your car will make it fail an MOT unless there just going to remove the guts and leave the cans ? 2008 G4 RRSport TDV8 current
Fri Nov 20 2015 1:19pm |
Yes, an SC. IMO to make it more SVR-like you'd have to remove the catalytic converters and all but the rear silencers and overfuel the car a bit (which means: a custom tune should be able to do the job). X-pipe instead of the center muffler frees up more of the V8 "burp". Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Sat Nov 21 2015 11:09am |
ok so the sounds of things we won't be able to replicate a svr lol
Sat Nov 21 2015 10:24pm |
I have replaced the centre section with a X-pipe and I haven't noticed the car to use any more fuel than the obscene amount it does anyway. Regards etc.,
Sun Nov 22 2015 9:28am |
whats the sound like with the x pipe on? have you got any videos? does yours still have the original back boxes? |
Sun Nov 22 2015 9:34pm |
I will record you a clip. Regards etc.,
Mon Nov 23 2015 10:59am |
did you manage to record a clip |
Wed Nov 25 2015 12:25am |
Hi, I hadn't had time before and had to ask my 6-years-old to record it using the phone, lol. Anyway, here you go.
Sat Nov 28 2015 2:19pm |
