![]() | Home > General > Blackbox Faultmate MSV-2 nano and software - whats it worth |
Triumph_Dave Member Since: 11 Jul 2013 Location: Somerset Posts: 124 ![]() ![]() ![]() |
I have a 2 year old Black box solutions Faultmate nano system with all cables etc and an unused single vehicle ( still non vehicle assigned ) license for a 2010 -2103 Range Rover sport. I purchased the system for my Disco 4, with a Disco 4 license and use it 3-5 times, then purchased a 2013 Black eddition RRS1 and changed the single user software license to a 2010-2013 RRS. However, the system and license were never used on the Range Rover and the license was never assigned to a vehicle, so is still open to be used.
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 ![]() ![]() ![]() |
Hi Dave
Its the HW015 model without the built in VCI1, for year 2005 onward CAN BUS types, although it will work fine with the external VCI1 available at 86 Euros on the BBS web site.
Hi, ideally windows Xp is whats needed, quite a lot of bog standard laptops available recon on fleabay for little money. I used my wifes old laptop when using it with the Disco 4 and it worked a treat, I was able to set up a rear camera ( after fitting the hardware ), initialise settings not switched on and check/clear codes. It worked 100% as advertised.
