Home > Technical > I'm leaning to the left
Corns-88
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
I seem to have developed a slight lean to the left. You can't see a front to back lean frm the side but the lefthand side (passenger) is definataly lower than the right. It doesn't drop overnight it just sits there. I'm assuming it needs its ride hieght sensors resetting or something or is there something I can do? 07 tdv8 stornoway grey at home tucked up
x type jag work and back hack
x5 Gone - never fully loved or cared for
Disco td5 gone - saved a fortune on ear plugs
Freelander gone - one of the first and worst
early disco gone- A tractor in a fur coat.
Post #478984 Fri Nov 06 2015 3:53pm
Tim in Scotland
Probably need a new sensor. if there is a fault then switch to the 4x4 Info screen on the central screen and the main display will show a red bar above the wheel where the sensor has failed 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #478991 Fri Nov 06 2015 4:37pm
smiler148
I had the same issue with my range rover sport when i picked it up.
Carried out a calibration of the suspension (requires the JLR software) and all has been well ever since. Was about 4 months ago. So hopefully wont be an expensive fix for you
Post #479015 Fri Nov 06 2015 8:02pm
PAS
England 2008 Range Rover Sport TDV8 HSE Santorini Black
I had this ,spent a few hundred at main dealer ,they couldn't calibrate it,they replaced 2 front sensor's ,yaw sensor,took off the 22" and tried it with standard 20",still couldn't calibrate ,the next step they said was to start changing the airbags,at this point I found out about Geoff (disco site)he came round with his IID tool and took him a little while but he got it levelled up for me.been ok since..touch wood
Post #479023 Fri Nov 06 2015 8:43pm
Disco_Mikey
Check the rod is not seized onto the link of the suspension arm. If it doesn't pivot, it can cause all sorts of weird suspension issues.
I normally have to go around all 4 and unstick them as part of a service. Once cleaned, and a bit of grease applied, they should be fine for a long time Thumbs Up
Post #479045 Sat Nov 07 2015 8:55am
Allycarson
Scotland
would seized rods bring on the fail light on the 4x4 panel as if it was a failed sensor mine has a light leen but doesn't get any worse Bow down
Post #530954 Sat Jul 22 2017 6:28pm
tom0311
United Kingdom 2009 Range Rover Sport Supercharged Autobiography Santorini Black
Had it on my first RRS. Needed a new ride height sensor on one corner and recalibrating. When you lower to access height does it show any wheels lower than others? Mine used to lower to access height OK but one corner would flash red on the 4x4 screen.
Post #530966 Sat Jul 22 2017 8:40pm
Allycarson
Scotland
4x4 screen seems too show ok
Post #530970 Sat Jul 22 2017 8:51pm
