Home > General (L494) > DAB signal loss |
Triumph_Dave Member Since: 11 Jul 2013 Location: Somerset Posts: 124 |
Has anyone noticed any issues with their DAB radio losing all channel reception. Just been out for the cars longest drive so far and in very moderate rain we lost every DAB station over a distance of about 50-60 miles, tried retuning the DAB stations and still nothing. We had at the same time a strange electrical overheat smell inside and the cars interior seemed to get warmer but zero smoke!. The smell passed in about 45 seconds, but then no DAB radio, we thought the smell/heat may have been related to the front climate control as the exterior temp dropped when the rain started.. Anyway, through this period the FM radio side worked fine, once the rain eventually stopped the radio started regaining DAB reception slowly in rough spurts, until magically its all started working again on all channels.
Sat Oct 24 2015 5:02pm |
iainm Member Since: 20 Mar 2015 Location: Cardiff Posts: 48 |
I had a similar problem with my DAB; kept dropping out for no reason. Went into the dealer - software update applied - touch wood - no repeat of the issues (Strastone Cardiff - Jamie - technician) |
Sun Oct 25 2015 9:45am |
Maidenmania Member Since: 13 Feb 2014 Location: Yorkshire Posts: 138 |
I have 2 friends with Fords and they lose DAB quite regular 2008 Factory HST- Sold
Sun Oct 25 2015 11:44am |
alexv Member Since: 02 Mar 2015 Location: beds Posts: 51 |
The land rover dab is crap I live in Bedfordshire and dab is so patchy its unreal, however my porsche dab is faultless even in the highlands of Scotland it is great, compare that with LR when in the highlands dab doesn't exist! On order expected October 16 macan turbo
Sun Oct 25 2015 12:54pm |
Interesting as I have recently driven mine from Stirling in Central Scotland to Southampton and then on to west London and apart from one short section driving over Beattock Summit in Lanarkshire I can carry DAB the entire trip, this was the same in both my previous Evoques and the 2010 FFRR. The gap in reception is due to the fact that there are quite a few hills around Beattock and I loose FM signals there too. It usually coincides with some crappy afternoon play on Radio 4 so I switch over to stream a talking book from my phone! One thing I find is that sometimes I have to do a manual DAB retune when I drive the A81 into Glasgow where the DAB doesn't seem to automatically retune in a hole in signals. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Oct 25 2015 3:05pm |
jasons Member Since: 26 Sep 2015 Location: Surrey Posts: 93 |
I have the same issue, in the RRS and also in my Evoque- theres a dead spot on the M25 around by Junction 10, affects both cars, so at leas tI know it just isn't one cars problem.
Sun Oct 25 2015 6:21pm |
Thanks ianm, sorry for the late reply but had to travel to the Americas on work... my DAB issue seems rain or water related, think I will do some testing when I get home and spray a hose over the antenna to see how much is needed for signal loss. The interesting issue on mine was that the DAB took ages to regain its signal after the rain had stopped, in all about 1 hour. Dave D4 2012 Santorini Black gone RRS 2013 Santorini HSE Black gone MY2016 RRS HSE Dynamic arrived September, but will it stay.. maybe not. |
Wed Oct 28 2015 5:20pm |
RRSporter Member Since: 08 Nov 2012 Location: UK Posts: 61 |
I know this is an old thread. But the Dab reception in my 16 has been noticeably worse (almost unusable) than the previous model sport I had. Not expecting much but I’ve located and changed the dab antenna amplifier this eve.
Wed Jul 22 2020 9:26pm |
Rowdie Member Since: 14 Jan 2015 Location: Uk Posts: 183 |
That's odd. My 14.4 has the same issue since about 3-4 months ago. Not on handbrake, but on occasions basely useable when driving, and sometimes absolutely fine...I I had assumed some area DAB transmitters may have been reduced, though it does seem better on BBC than the non BBC channels ?? Is yours the same ? I do have a feeling its worse in bad weather, but not conclusive |
Thu Jul 23 2020 12:58pm |
RRSporter Please do advise if your change fixes the issue... |
Thu Jul 23 2020 12:59pm |
Will do 👍. I’m out of my local area but initial signs are not encouraging. What I haven’t been able to see is where the coax terminates into the rear screen in case of any corrosion etc there. I do know a £50 site radio sat on the passenger seat will comfortably trump the built in kit which tells me there must be a fault in the antenna circuit somewhere.
Fri Jul 24 2020 12:15pm |
Yes BBC are least bad. Something like talksport 2 appears to be a good test of marginal reception. But I have times where even Bbc goes no reception on and off. 3.0 SDV6 HSE L494 |
Fri Jul 24 2020 12:24pm |
No change sorry. I haven’t given up though. Still suspect the antenna input somehow to the dab module just not sure what’s up? 3.0 SDV6 HSE L494 |
Fri Jul 31 2020 9:10pm |
Thanks for the update. Silly question. Have you changed where you keep your mobile phone in the car. I have started putting mine in the central coffee holder and I have a tiny hunch it might be affecting the DAB signal but not proved conclusively yet. |
Sun Aug 02 2020 7:52pm |
