Home > General (L494) > DAB signal loss
RRSporter
Hi
No I haven’t to be honest. I’m working through stuff as time allows. Tried can amplified aftemarket antenna direct into dab module. It’s a stick on window job and performs slightly worse than factory antenna.
I’ve found a local station that can give no reception parked up, but when I open the boot it works! Which leads to suspect chafed wiring but I can’t see any evidence of this on inspection. I guess it’s just better position of the antenna when the tailgate is open? Higher is always better 👍.
Not terribly useful. I do suggest a roof mounted aftermarket antenna would improve reception but I’m still trying to find the main dealer solution 🤞. Maybe another module is an option esp a later one with newer software? 3.0 SDV6 HSE L494
Post #603121 Mon Aug 10 2020 11:10pm
