Home > General (L494) > Which Engine SDV6 / SDV6 Hybrid / SDV8 / V8 Supercharged
Page 1 of 3 123>
GJW1
Having driven the SDV6 i have for a couple of weeks the Lag or inability for the car to know which gear to be when coming to a roundabout which is widely reported i dont know if i can live with it or on my new build pay the extra £6.5k for one of the other engines.
Can i see some real world pros and cons for each engine from owners who have them.
Pros for the SDV6 from me
Nice quiet engine for a desiel at startup.
powerful enough when it has the right gear.
almost silent from inside which is great for long trips.
nice sound when you want to push it that bit harder.
Cons
Lag - when trying to pull away from roundabouts and having no power for that fraction of a second. The only slight way around this is in sport dynamic in either one or the other it doesnt help. In sure the car sits in 3rd when it should be in second hence no pull.
If this can be sorted with one of the other engines or even all the other options im considering the change.
My car is used for work, holidays and school runs so i dont need a bigger engine unless the issue is solved then i would consider the extra money.
Over to the next person.
Post #477587 Fri Oct 23 2015 10:08pm
JSR2014
England 2013 Range Rover Sport Supercharged Santorini Black
Ok,
I have driven the SDV6 for 10 days straight and own the SC.
No lag on the S/C V8
The SCV8 wins hands down if you can live with 20MPG real life, 25 on the motorway and 18 on rural b-roads, 12-15 if pushing it.
The lag on the SDV6 annoyed me, but having had a diesel XF I was ready for it.
Having said that, they were both AB's but my wife was ADAMANT that the 5.0 S/CV8 had softer leather and more comfy seats, I was too busy cursing the engine Wink 2014.5 Mariana Black 5.0 Supercharged V8 Autobiography
Post #477589 Fri Oct 23 2015 10:13pm
Renaco
The Hybrid has no lag, in dynamic mode and start-stop in off position, it pushes away like hell.
The electric torque of 170nm is available from 0, combined with the SDV6 torque of 700nm it is the quickest diesel in the Land Rover line.
The SDV8 is the greater sound, but for me a bit yesterday in balance as the heavy engine above the front arch kills the sporty feel of the RRS with the lighter engines.
Drive both a weekend and then you know whats yours... Very Happy
Post #477625 Sat Oct 24 2015 12:19pm
Mark_N
If I plan to drive (say), 12000 miles in my SVR, average MPG for the driving I do about 20, certainly no less and on a longer run, more. 600 gallons a year, 2725 litres, £3500 pa if you put super unleaded in it.
For diesel, assume 30 mpg, 400 gallons, 1820 litres, £2100 pa.
There's no comparison in the performance and refinement (not to mention absence of lag) you will get from the SC. To my mind, the SC is more than worth that extra cost.
The spoiler (for the SC) is that the residual value is marked down by a market which hasn't done the maths and is paranoid about the SC running costs. Mark
SVR in Estoril Blue Thumbs Up
Post #477631 Sat Oct 24 2015 2:47pm
Mark_N
I'm afraid you are mixing up torque and power. It's not torque which gets you up to speed, it's power. Mark
Post #477632 Sat Oct 24 2015 2:54pm
gary3306
England 2013 Range Rover Sport SDV6 Autobiography Fuji White
Its you who is wrong Mark. Torque 'AT THE WHEELS' gets you up to speed. Horsepower is only a made up figure derived from multiplying the torque figure with the RPM and dividing that by 5252. On arolling road, the HP is worked out from the torque being produced.
The torque produced by the engine alone, and the resultant horsepower, wouldn't do too much to pin you back in your seat as your car takes off at a ridiculously fast 0-60 time. What does this is gearing and drive train. How the torque is multiplied via the transmission is what does the business.
Think of it this way; a big ocean going cruise liner may have a listed 10,000 horsepower, but I wouldn't fancy its chances against me in a pedal powered wheelbarrow. If there was a transmission that could be fitted to it that multiplied the torque accordingly, well I wouldn't mind a white knuckle ride on it. You might say 'yes but look at the size and weight of one of those'
The power to weight ratio would be immense, so that isn't an argument lol.
So torque and horsepower are infinitely linked, as the HP figure is derived from the torque figure in the aforementioned formula.
Torque wins races!
Post #477636 Sat Oct 24 2015 3:53pm
parish
I have test driven both the SDV8 and SDV6. The only evidence of lag - if that's what is was - was on the V8 where I went to pull out of a junction and the car hardly moved. Luckily it was a quiet junction otherwise I would have been in the doodoo.. The salesman actually suggested it was my driving as I did not push the peddle hard enough he said...tosser. I think it was in the wrong gear personally as I had not come to a complete stop before trying to pull away. To be honest didn't notice any problems on the SDV6.
I am no an engineer but I believe lag is a feature of turbochargers only that most modern Diesel engines use. The SC uses a supercharger (get away I hear you say) which is why there is no lag. Every diesel car I have owned has suffered from lag to some extent, even the Macan I just sold (it was surprisingly bad actually). The least laggy was a BMW 640D. I think this is all to do with how the engine is tuned and mapped but no doubt there are more knowledgable people out there than me who could confirm this.
Interestingly, the one diesel I have driven (but don't own) where there was no noticeable lag is the Volvo XC90 D5. Volvos new generation of engines use a combination of both turbo and super chargers.
Post #477638 Sat Oct 24 2015 3:56pm
R444SPT
So having driven an SDV8 for seven months and now temporarily in an SDV6, I will be very pleased to go back to the SDV8.
I did consider the supercharged, but overall increase in running costs for a car that most of the time is cruising with the flow of the traffic I couldn't justify, along with the comment on residuals already made.
I do think the residuals may be hit further in 2-3 years as the 2nd hand SVR market picks up ( any colour you want so long as it is blue)
My SDV8 had 22" wheels and the SDV6 only has 21, this also has an effect on the ride, I do know the SDV8 didn't struggle with anything, whereas the SDV6 has to work hard, shown by e engine ecometer reading, and is no where near as tight in the corners. Of course perhaps my driving style and having had V8's for some years before influences that decision.
sdv8 MY15 sdv6 MY 15.5 next to arrive MY16...
Post #477639 Sat Oct 24 2015 4:01pm
GJW1
parish wrote:
I have test driven both the TDV8 and SDV6. The only evidence of lag - if that's what is was - was on the V8 where I went to pull out of a junction and the car hardly moved. Luckily it was a quiet junction otherwise I would have been in the doodoo.. The salesman actually suggested it was my driving as I did not push the peddle hard enough he said...tosser. I think it was in the wrong gear personally as I had not come to a complete stop before trying to pull away. To be honest didn't notice any problems on the SDV6.
This explains the problem well you don't come to a stop as there is space to pull out but the car I think isn't in the correct gear it's not all the time thoug only sometimes maybe 25% so depends on the throttle pedal position and various other factors however it isn't a nice feeling and if I can avoid it with a engine upgrade in my new order I'm tempted to do it.
Post #477642 Sat Oct 24 2015 4:16pm
gary3306
Or maybe I could explain easier using the Bugatti Veyron as an example. Car has a top speed of about 210mph and a 0-60 time os about 2.5 seconds. It produces 922lb/ft of torque and has 1006BHP or thereabouts (derived from the torque figure)
Now; don't touch the engine whatsoever, so it is still producing the same figures, but now fit a Vauxhall Corsa transmission and running gear. Obviously the torque produced by the engine would destroy the transmission in reality, but the point I am trying to make is ; now what would its top speed be and how quick would it get there? Very Happy
Post #477643 Sat Oct 24 2015 4:21pm
Big-Daddy
I've driven the V6, V8 and SC, and the first RRS2 I had was the SC which was great fun, but I switched to the V8 4.4 because when your towing 3 tonnes across a muddy field there really isn't any other option in my opinion.
So, it kinda all depends on what you want out of it, if you like tearing up the road, always go for the SC or SVR, If you drive gently and want a long lived fairly economical drive then the V6, and if like me your towing or off-roading then the V8.
Again, my opinion, but I did swap from the SC to the V8 because it performed better in the environment I drive.
Post #477662 Sat Oct 24 2015 7:13pm
GJW1
You say refined is it really ? My dealer doesn't have one in and not one close so I can't test one but another thing on my mind is the noise been intrusive to the almost silence the car has when cruising in my sdv6.
Post #477665 Sat Oct 24 2015 8:08pm
R444SPT
Having driven all three, I would say the petrol engine is thE smoothest,
In terms of cabin noise crushing I would rate the sdv6 least. Of course hard accelerating on the sc, gives a noise, which is part of the fun!
Post #477667 Sat Oct 24 2015 8:30pm
Mark_N
Yes, I missed the comment that Renaco was referring to diesels only.
The only difference between a car at 60 and a car at rest is the one at 60 has kinetic energy. It follows that the greater the ability of the car to create that kinetic energy, the faster it will be. The kinetic energy comes from the power of the engine (Power in Watts = 2* PI * Engine Speed (revs per second) * Engine Torque (newton metres)) so that it's both the engine speed and engine torque which has a bearing on the performance. Ignoring losses, an SVR accelerating to 60 mph in 4.5 seconds is averaging around 200 kW or about 270 bhp. An SDV8 has higher torque than an SVR but is slower to 60 because its peak engine speed and therefore power developed is lower.
Once up and running, the engine speed can be matched - more or less - to the speed of the wheels through the transmission but at low speeds, there has to be some slip in the transmission - clutch or torque converter - to allow the engine to run at a viable speed while the road wheels are close to stationary.
That's the great advantage of electric motors - their torque is generated even if the motor is stalled and the additional torque contribution contributes to a better take off from standstill. That's why the Tesla electric cars are achieving such spectacular standing start performance figures. Mark
Post #477700 Sun Oct 25 2015 1:18am
Mark_N
The SC and SVR are more performance orientated cars and are expected to make more noise when being worked hard. My SVR is very quiet and refined on a relaxed motorway cruise on a trailing throttle with the hooligan options turned off.
Diesels run at higher compression ratios so there is a bigger bang at each cylinder detonation. It's that extra cylinder pressure which contributes to the noise and if LR have managed to tame it in normal driving, they've done a good job. The only diesel I've driven was at the Land Rover Experience in Eastnor Castle and it was a clattery old thing but that might have been down to its usage history. Mark
Post #477701 Sun Oct 25 2015 1:38am
Page 1 of 3 123>
