Home > General (L494) > Which Engine SDV6 / SDV6 Hybrid / SDV8 / V8 Supercharged |
I think the reason for the Hybrid being rare as hens teeth in the UK is that here it is a bit pointless, the range is less than 1 mile on battery and the cost is huge. If you live in London I suppose there is the added benefit of not paying congestion charge, but then there are much better hybrids for inner city driving than a hybrid Range Rover Sport and they mostly cost a lot less too 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Oct 25 2015 6:38pm |
Violetpiano Member Since: 03 Jun 2014 Location: London Posts: 561 |
I drove all 3 before putting pen to paper. I only do around 7k miles per year and as most of my driving is motorway driving, mine has averaged just over 22mpg since I have had it. But as some have already mentioned a 7 mile drive through the middle of London in traffic or when pressing hard on B roads it comes down to around 11mpg.
Mon Oct 26 2015 11:40am |
Renaco Member Since: 28 Jul 2011 Location: Bavaria Posts: 324 |
Seems you dosent read my posts. I wrote several times, the Hybrid is the best diesel RRS in the dayli use. Best torque from 0, better balanced than the sdv8 and coolest badge... So for me, its the only Option for an L494 the SC V8 or the Hybrid. The SDV6 is good, but less impressive to drive, the SDV8 good but to unbalanced because of the heavier Engine. |
Mon Oct 26 2015 6:39pm |
parish Member Since: 15 Oct 2015 Location: Bucks Posts: 58 |
Renaco, assuming it's the hybrid you own, what real life mpg are you getting ? |
Mon Oct 26 2015 6:48pm |
EVO1 Member Since: 11 Mar 2012 Location: Cannes Posts: 23 |
I have a Hybride autobiography Dynamic and I'm very happy with. Smooth and fast.
Mon Oct 26 2015 7:09pm |
sorry, mpg I am not used to, the Hybrid is between 7.5 to 9.5 Liters/ per 100 km.
Thanks Renaco (and EVO). Apart from the economy not providing any payback on the extra cost of the hybrid engine, I think LR miss a trick in not offering the it as a choice below AB variant level (in the UK anyway). That unfortunately makes it just too expensive for a lot of buyers I think. |
Mon Oct 26 2015 7:17pm |
GJW1 Member Since: 19 May 2015 Location: UK Posts: 447 |
Hi Renacoi did see your post thanks. I thought with its battery it might work on its own for a while longer than 1 mile that kind of doesn't seem right even for such a heavy car.
Mon Oct 26 2015 8:15pm |
mikef Member Since: 16 Sep 2013 Location: bucks Posts: 313 |
You are right to be concerned about the lag on the SDV6 engine when attempting to pull on to a roundabout because its a definite characteristic of the car although IMHO its not a problem with the engine but with the ZF 8 speed gearbox which exhibits a similar trait in other cars I've driven which have been fitted with it. FWIW I got my SDV6 remapped and that masks the throttle lag a bit but certainly doesn't eradicate it. You do learn to drive around it but it shouldn't be there in a car costing so much |
Mon Oct 26 2015 9:56pm |
Cantona Member Since: 27 Oct 2015 Location: Cheshire Posts: 518 |
Re the lag on the v6, is that why the horse power has been slightly improved in the new model? (he says hopefully).. |
Tue Oct 27 2015 10:07pm |
Nope as mine is the MY16 so the latest car it's not a deal breaker on he car it's just borderline for me at the moment on whether I can live with it or order the sc instead which as people have said doesn't have it or infact I haven't seen any of the other engines report the problem only SDV6 owners seem to have it. As above If it's gearbox related then I don't get why the other options are ok with the same box.
Tue Oct 27 2015 10:14pm |
I test drove it and did'nt come across anything untoward if I'm being honest. I am trying hard to tame the boy racer within (I'm 50 ), that might have something to do with it.. |
Tue Oct 27 2015 10:26pm |
It's not all the time borrow one for a couple of days you will feel it a few times depending on driving style I'm sure. It's not a deal breaker as I say though.
Tue Oct 27 2015 10:34pm |
Christ, from a 911 to a sitting duck |
Tue Oct 27 2015 10:36pm |
