Home > General > Prolonging life!! (Car parts not me, I have no hope) |
Wilson Member Since: 06 Oct 2015 Location: Ipswich Posts: 78 |
Probably not a definitive answer to this but I'm interested on other people's views!
Sat Oct 24 2015 10:58am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Probably a good idea to cycle it through occasionally if the settings don't get used, but the compressor will be used anyway during normal use. The one thing it is best not to do too much, is to use access height, as this will require the compressor to run more. Visiting from DISCO3.CO.UK
Sat Oct 24 2015 11:27am |
frostmotorsport Member Since: 14 Apr 2014 Location: Wellington Posts: 79 |
Well... I use access height every time I stop the vehicle - so I assume my '05 compressor must be dead by now. But it's still working and the whole system doesn't lose air, even over long periods of rest.
Sat Oct 24 2015 4:59pm |
On the climate control front, it's a nice feature that when left on "Econ", it will still run at around 5% to keep the seals from drying up. Visiting from DISCO3.CO.UK
Sat Oct 24 2015 5:06pm |
I don't really have much need to change from middle height myself.... I've put it on high when I've had to park in a tight car park but that's about it... Oh and today when I removed the tow bar!!
Sat Oct 24 2015 7:01pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
So the seals are fresh but the cabin is unpleasant. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Oct 24 2015 9:00pm |
It's wasted if I have the window open, and has little bearing on short journeys, which may far from make up the bulk of my mileage, but in frequency over time, is a large percentage. The cycle of the refrigerant has no relevance to the heating side of things either, so the swashplate compressor is an excellent feature in my mind. Visiting from DISCO3.CO.UK
Sun Oct 25 2015 8:37am |
