![]() | Home > General > knocking noise |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
I think the steering column UJ is more akin to feeling like you are steering with a 50p piece, ie notchy.
Take it to a good independent dealer for them to look it over....... |
Alex C Member Since: 09 Jun 2013 Location: Southampton Posts: 146 ![]() ![]() |
Had my steering UJ replaced last week, TDV8 with 85k. Difference is really noticeable, had already done bushes, rollbar and ball joints previously and there was still a 'shake' through the steering in certain positions as you pulled away from low speed, all gone now. |
PAS Member Since: 30 May 2014 Location: kent Posts: 70 ![]() ![]() ![]() |
had my lower steering column done few weks ago,the symptoms i had where when turning at bottom of a hill got a knocking sound ,Sometimes going over uneven road surfaces,,I have done my upper & lower wishbones ,check that you have got the weight's fitted that dampen steering noise,mine is a 58 &didn't have them fitted |
Alfie Member Since: 21 Dec 2014 Location: Peterborough Posts: 141 ![]() ![]() ![]() |
I would say that the symptoms are as codfather described , noise when you go over a pothole / bump , I will ask a local garage to have a look at wishbones etc , could be expensive then !![/quote] |
Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312 ![]() ![]() ![]() |
Hi Alfie, the ARC bushes are not an MOT failure. I tried to get them done on warranty but since they are not an MOT failure issue they didn't cough up |
Front lowers would be my bet if they haven't been done yet. |
foxtrotzulu Member Since: 04 Sep 2015 Location: West Berkshire Posts: 152 ![]() ![]() ![]() |
I think you'll find one of these has come loose and is rattling.
jje Member Since: 03 Feb 2015 Location: essex Posts: 8 ![]() ![]() ![]() |
I have a 2008 TDV8 purchased a year ago from a JLR dealer in Essex with 48,000 from new (Grange Motors),a week after I got it I heard a knocking sound when travelling over pot holes or rough road surfaces and there are lots around here.I took the vehicle back and front lower wishbone wear was diagnosed,these were replaced under warranty and off I went,next day same problem,back in again and the front ARB bushes were replaced,took it away and same problem but after reading a posting on here regarding updated ARB clamps I asked if they had been replaced,NO was the answer,they were replaced and so far all has been well for 4k miles.
