Home > Faults & Fixes > Radio screen/sat nav screen don't turn off help!
Harry HST
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Java Black
Hi
I've had my battery replaced and since then when I lock the car the sat nav screen or the radio screen stays on and drains the battery.
Has anyone had this its usually one or the other or both or sometimes it doesn't even do it.
Please help !
Thanks.
Post #363612 Sun Nov 18 2012 10:33pm
jgrime99
Has anyone else had this. I have had it whereby when I turn the engine off the radio and sat nav console area turn back on.
It has happened for about 2 months. Tonight I have a flat battery. I can only assume they are linked.
Is there a fix for this or is it a trip to the garage that is required?
Thanks
Post #433660 Mon Aug 18 2014 9:45pm
benj193
Mine does this. if you put the key back in, turn it over, and turn it off again the screen should go off as well.
Post #477389 Thu Oct 22 2015 2:20pm
