Home > Maintenance & Modifications > autobox oil change
blueiceplus
United Kingdom 2008 Range Rover Sport TDV6 SE Cairns Blue
autobox oil change
just fitter a new quick fit sump to my 2008 RRS Laughing which came with 7lts of oil, on measuring the oil that came out, there's only 5lts Rolling Eyes Rolling Eyes Rolling Eyes the box as no leaks, should I put in the other 2lts in or is 7lts for doing a complete oil change Sad also I have just heard that if you change the oil, being new the detergent in it, can dislodge any s**t in the box, and cause problems Evil or Very Mad and were do you refill it at, I found a blanking plug on the o/s just above the sump ?
Post #476789 Sat Oct 17 2015 3:53pm
RogerDeFlor
If you just drain the oil by undoing the drain plug, only about a half (to a quarter) of the oil will come out. To completely drain it, the gearbox needs to be run and cycled through the gears. The spec for the ZF 6HP26 (as fitted to the 2.7 diesel), has a capacity of 9.5 litres.
A dealer, or independent garage should be able to do a "double flush" which will be more effective.
As for dislodging any sludge, there seems to be an even split of opinion on whether to do the oil change. But if it's done early enough, there shouldn't be a problem. My local LR indie said LR now recommend a gearbox oil change at 75K miles.
I've just had mine done at a cost of about £300. Thumbs Up
Post #476793 Sat Oct 17 2015 4:42pm
Lost for Words
It's fill to spill as long as it's at the correct temperature (and engine running, and you've cycled through the gear positions) - around 35 degrees is ideal IIRC. Around 5l is normal though. Thumbs Up
If there's any Censored in the box, you have problems already. On high mileage boxes, changing the fluid can reveal issues that were otherwise masked by contamination from the stator bush. Wink Visiting from DISCO3.CO.UK
Post #476794 Sat Oct 17 2015 4:43pm
duncmc
United Kingdom 2005 Range Rover Sport TDV6 HSE Tonga Green
RogerDeFlor, where did you get yours done?
I want to get mine done and work in Gloucester half of the week.
Post #476797 Sat Oct 17 2015 5:14pm
garrycol
Australia
BlueIcePlus - if you are going to work on your own vehicle you need to read the workshop manual first so you know what you are doing. The way you are going about it you will do damage to your vehicle.
What Lost for Words has outlined is the summary of how to do but please read the process in the workshop manual (relevant section on Topix) first.
If I knew how to load an XPS file to this post I would have put up the relevant sections here. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #476865 Sat Oct 17 2015 11:07pm
Lost for Words
Pan and Filter Change: http://www.disco3.co.uk/gallery/albums/use...nstall.pdf
Fluid Drain and Re-Fill: http://www.disco3.co.uk/gallery/albums/use...Refill.pdf
Level Check: http://www.disco3.co.uk/gallery/albums/use..._level.pdf
Thumbs Up Visiting from DISCO3.CO.UK
Post #476886 Sun Oct 18 2015 7:39am
RogerDeFlor
I used Tim Fry Landrovers in Cheltenham. They seem pretty good. Thumbs Up
Post #476907 Sun Oct 18 2015 12:28pm
jenko2005
Wales 2006 Range Rover Sport Supercharged Zambezi Silver
I had a mega flush on the gearbox yesterday arranged by gilly, the mega flush removes all oil from gearbox and puts in about 11-12 litres
Post #476910 Sun Oct 18 2015 12:48pm
duncmc
Thanks RogerDeFlor.
I think I really should get a megaflush done. Did TimFry do one of those? Or just a normal change? Thanks.
Post #476927 Sun Oct 18 2015 4:44pm
