Home > Technical > CRUISE CONTROL - SPEED CHANGES |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
Hi, Had a seach on the forum but couldn't find anything on this issue.
Fri Oct 16 2015 8:12pm |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 |
Mine is an SDV6 but it holds speed within a couple of K's but will over speed on a steep downhill run.
Sat Oct 17 2015 7:00pm |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
Mines pretty useless on downhill '30s' I must admit. |
Mon Oct 19 2015 5:38pm |
Sorry Fellas if you think I was exaggerating with those speed changes.
Fri Oct 23 2015 6:35am |
Cracka,
Fri Oct 23 2015 8:45am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Piffle really. The transmission does limit the amount of negative torque permitted, but at the end of the day, the car has access to full braking should it need it so it's not really an excuse. Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Fri Oct 23 2015 9:15am |
Thanks Fellas I'll give the sports mode a try next time, that will at least cut out the overdrive . |
Sat Oct 24 2015 2:27am |
