![]() | Home > General > TDV6 vs SDV6 ? |
2.7 TDV6 or 3.0 TDV6?
Goffie01 Member Since: 19 Nov 2013 Location: Shropshire Posts: 20 ![]() ![]() ![]() |
Yes i was refering to the 3.0L version. So if i understand you correctly when looking at the RRS the diffrence is the new 8 speed Command shift box ? The engine is the same . ? |
Yes, the engine is physically the same. The mapping provides a little extra power, but there's little in it; the gearbox is the main difference. |
Thanks for that. They do like to confuse things . I had an 11 plate D4 with SDV6 and 6 gears . |
They certainly do! In reality, SDV6 is the "correct" name, IMO, as the S stands for sequential. |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5638 ![]() ![]() |
I had MY10 3.0 TDV6 for 3 years and MY13 SDV6 for 2 years - the SDV6 was far better in every way |
That will probably explain why the price of the TDV6 is so much lower . I changed my D3 for the D4 and as you say the diffrence was awesome. Asssume this applies for the upgraded engine as well. |
