Home > Technical > Suspension Warning Light???.... Yup another of these posts! |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 |
I would look at battery and what voltage it is holding, a drop in volts will give some strange faults.
Sat Oct 10 2015 4:43pm |
RogerDeFlor Member Since: 28 Mar 2015 Location: Gloucester Posts: 51 |
If the suspension height drops when it has been parked for a couple of days, then it indicates that there is a leak in the air system. This is usually one of the air springs leaking, but could also be one of the valve blocks. It's easy enough to diagnose yourself, by disabling the air suspension computer, and seeing which corner drops.
Wed Oct 14 2015 3:32pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
More likely a valve block than a leaking suspension air bag.
Wed Oct 14 2015 8:51pm |
Flinders Member Since: 12 Dec 2014 Location: West Yorkshire Posts: 126 |
Thanks everyone. Some great tips on what to look at. There is only the one warning light and message so not sure it will be the battery. I will get voltages checked though and get her checked for the leaks.
Fri Oct 16 2015 3:30pm |
