![]() | Home > General > Windscreen squirters are rubbish |
Wilson Member Since: 06 Oct 2015 Location: Ipswich Posts: 78 ![]() ![]() ![]() |
Having recently picked up my 07 TDV8 and loving it so far, I was surprised at how rubbish the screen squirters are, they reminded me of an old 80's Ford Escort I had... They work but how dated for what is a modern vehicle to me, I thought all cars over the last 15-20 years had good strong spray jets that cover the windscreen in fine screen wash!
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
Mines a 05 and I think they're quite good. Are you sure they're not clogged up? |
Definitely not clogged up, I just thought there might be some replacement that sprayed across the screen like other modern cars! |
It's not a major problem, and I feel a bit petty pointing it out |
jasons Member Since: 26 Sep 2015 Location: Surrey Posts: 93 ![]() ![]() |
Let me know how you get on, I would be interested as its not petty.... Is it??? ![]() |
If you think there bad now, just wait for the cold weather, then there useless !!! 2008 G4 RRSport TDV8 current
whaaaaat??? they're not even heated?!!! |
Yes there heated but they still freeze up I think it's the pipes that freeze not the jets 2008 G4 RRSport TDV8 current
I wonder what fitment they are and if jets from a different vehicle could be fitted, like these as example after a brief search
You could try fitting a set of RRS2 or Evoque nozzles and see how they clear the screen 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
I don't see how a finer spread of water would be any better; it's volume that's needed and more jets, with more water would be great, but then you'd run out all the time/need a bigger tank.
Get some of the latest ones, as fitted to the facelift models. They have better heating elements that actually work and have, in fact, supeceeded the original ones. Jets are the same, however. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Ian.H Member Since: 04 Oct 2014 Location: England Posts: 180 ![]() ![]() ![]() |
They're better than the ones on my classic Mini.. the jet streams hit the wiper arms instead of the windscreen unless you turn the wipers on at the same time |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Something's not right.
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 ![]() ![]() ![]() |
Well here in sunny downtown Melbourne we have more rainy days than other places in Aust. But, our rainfall is one of the lowest in populated areas. In other words we have lots of drizzle and light rain.
