Home > Technical > Sat Nav on the move |
Funny you should mention that Josh.... this happened to me the other day too. I wanted to set a route after I'd actually set off and tried and voila! it worked where it certainly never used to. I haven't had any updates done though.
Thu Aug 03 2006 10:00am |
p-trax Member Since: 08 Apr 2006 Location: Herts Posts: 64 |
I think the only restrictions are entering a new address/postcode whilst in motion. If you recall a previous entry or a strored (ie HOme) address then it all works fine. The further restriction is that you cannot scroll through previous entries, so you only see the last 4 Stornaway Grey/Ebony TDV8 HST, September 3rd |
Thu Aug 03 2006 10:16am |
That would make sense... I was using the home destination...
Thu Aug 03 2006 10:35am |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
I sure the latest update fix this RRS TDV6 Gone but still around
Thu Aug 03 2006 10:40am |
