![]() | Home > Technical > Sat Nav on the move |
Funny you should mention that Josh.... this happened to me the other day too. I wanted to set a route after I'd actually set off and tried and voila! it worked where it certainly never used to. I haven't had any updates done though. |
p-trax Member Since: 08 Apr 2006 Location: Herts Posts: 64 ![]() ![]() ![]() |
I think the only restrictions are entering a new address/postcode whilst in motion. If you recall a previous entry or a strored (ie HOme) address then it all works fine. The further restriction is that you cannot scroll through previous entries, so you only see the last 4 |
That would make sense... I was using the home destination... |
I sure the latest update fix this RRS TDV6 Gone but still around
