Home > General (L494) > First thoughts ..and concerns, after 2 weeks |
Can relate to some of those observations. One of my other toys is a 993 C4 cab with bone-jarring Bilstein suspension and modified exhaust bordering on the 'offensive' . The contrast with magic carpet ride and civilisation of the RRS is rather marked to say the least. 2008 MY Java Black TDV8 HSE
Sun Oct 11 2015 8:56am |
Bobajobbob Member Since: 01 Jun 2015 Location: Kent Posts: 137 |
No big concerns with mine but the screen isn't quite level, the lights appear to be setup too high and there is no obvious place to put the keys. Otherwise loving it. |
Sun Oct 11 2015 9:34am |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
Yes! It bakes the outer side of my left leg, the knee in particular due to the way I rest it against that trim. So I am not the only one then. I bet if we reported it to the dealers they won't be able to do much about it and just class it as a "characteristic". Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond |
Sun Oct 11 2015 9:35am |
My headlights were also set too high. Had the dealer adjust them. Yet to see if oncoming cars still flash their headlights at me at night. Tyre pressures were too high and I corrected it - worth checking before it causes any damage. These prompted me to get the 4 wheel alignment checked at an indie yesterday but glad that was good. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond |
Sun Oct 11 2015 9:39am |
J1220 Member Since: 26 Sep 2015 Location: London Posts: 17 |
fkarim: what should the correct tyre pressure be? |
Wed Oct 14 2015 9:44am |
If you press the starter button without your foot on the brake you will be able to access the "Service Menu" in the dash board by pressing the Menu button on the steering wheel. Scroll to Tyre Pressures and the TPMS screen will come up. On that there are two sets of numbers for each tyre. The number in square brakets [38] is the required tyre pressure, the other number is the measured pressure. Otherwise if you open the driver's door, down to the left just above the sill is a chart with all the pressures for each size of wheel and the loading of the car. They are also given in the owner's manual. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Oct 14 2015 10:23am |
Thanks |
Wed Oct 14 2015 7:51pm |
Bohdathone Member Since: 28 Sep 2015 Location: Edinburgh Posts: 3 |
Felt I should give an update for this. Dealer eventually located the rattle after several test drives and "dismantling over three quarters of the dash", which was apparently a loose hevac unit. LR told them to drill holes and actually rivet it in place which worked - anyway, a thousand miles later it's still ok.
Fri Dec 04 2015 1:16am |
mikef Member Since: 16 Sep 2013 Location: bucks Posts: 313 |
You're fortunate you've only experienced one dashboard rattle. I have had 3. One disappeared when my local stealer did the blower wire recall but the other 2 are persistent. My car went in for service last week and the stealer ignored my request to investigate the other rattles. Its a fact of life with L-R products. They're not screwed together as well as the German competitors so owners invariably have to put up with trim rattles and squeaks |
Sat Dec 05 2015 7:34pm |
