![]() | Home > General > Tdv8 2008 ringing noise |
Is it on the engine ie goes up and down when you Rev the engine ? Or is it on the trans/ road wheels etc ? 2008 G4 RRSport TDV8 current
Alfie Member Since: 21 Dec 2014 Location: Peterborough Posts: 141 ![]() ![]() ![]() |
Sounds like it's coming from near side front wheel , so I'm guessing it could be brakes or bearing |
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 ![]() ![]() ![]() |
Does it do it at all speeds? I have something similar but only on load from approx 50mph up. So far, 2 independents have been unable to diagnose.... 2010 TDV8 |
Hi , I would say it is more noticeable when you done a few miles ( warmed up a bit ) and generally noticeable at low speeds around town , it's less noticeable when you travel above 30mph because the engine noise and road noise makes it difficult to hear , I will get a better idea on Tuesday when it goes for an mot so any play in the wheel bearing and brake condition will be inspected |
