Home > Maintenance & Modifications > Battery warning light/low power mode
redson
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Hi
I got the dreaded battery warning light a couple of days ago and yesterday noticed the stereo in low power mode, althgouh this appears intermittent.
Using the system check voltage is reading 11v both before and after ignition/turnover which seems horrendously low, no? Confused
Battery is about 6 months old. Everything else working fine otherwise. Have seen others on here with similar symptoms. There's no suspicious smells from under the bonnet. Will an ECU reset be worth doing or is it likely to be a new alternator? Any ideas?
TD V8 2007. ACE (I think - it has factory Brembos) TDV8 2007 window tints, Logic 7, side steps.
Post #475174 Sat Oct 03 2015 6:59pm
DrRob
Take it to Guava in Guildford or Rovertune in Reading and get them to stick it in the diagnostic......? Visitor from fullfatrr.com
Post #475179 Sat Oct 03 2015 7:13pm
Lost for Words
I'd get standing charge and alternator readings with a proper multimeter and go from there, but if your saying the screen reads 11V with the engine running, then it certainly sounds like your alternator is dead. Thumbs Up Visiting from DISCO3.CO.UK
Post #475218 Sun Oct 04 2015 10:02am
redson
Update: complete system meltdown this morning. No screen, Limp-home mode, warning lights all over the place Big Cry TDV8 2007 window tints, Logic 7, side steps.
Post #475244 Sun Oct 04 2015 12:55pm
