Home > Maintenance & Modifications > Front/rear diff oil change & transfer box |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Yes, exactly the same.
Tue Sep 29 2015 6:17pm |
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 |
Great, thank you kindly for your reply, |
Tue Sep 29 2015 8:33pm |
Mmmmm just phoned Land Rover and they tell me front rear diff takes 2.1 litres and transfer box takes 3 litres, that's not correct is it? |
Wed Sep 30 2015 8:45am |
No. Visiting from DISCO3.CO.UK
Wed Sep 30 2015 8:47am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4388 |
Front diff takes 0.6/0.7 litres, and the rear p, from memory is around 1.5 |
Wed Sep 30 2015 8:49am |
Yes, thought they were way of the mark, and it's ok to use same oil in diff and transfer box, So if I get 4 litres diff oil that should be adiquate for all 3.. Sorry for being bit dumb it's just want to make sure as its about 50 mile round trip to Land Rover. |
Wed Sep 30 2015 10:00am |
I used this in all three and haven't noticed any issues: http://www.advancedfactors.co.uk/tyk500010...-311-p.asp Yes, 4 litres needed to cover it.
Wed Sep 30 2015 10:17am |
Cool Thank you yet again, |
Wed Sep 30 2015 11:26am |
Not at all; you're most welcome. Visiting from DISCO3.CO.UK
Wed Sep 30 2015 3:06pm |
I've been reading about the front diff breather filter causing pressure build up due to the factory filter restricting air flow, so is it recommended to do the filter mod. |
Thu Oct 01 2015 5:40pm |
Yep, never a bad thing to do, just chop the old one off and stick one of these on: http://www.advancedfactors.co.uk/lr019450-...5131-p.asp Visiting from DISCO3.CO.UK
Thu Oct 01 2015 5:59pm |
Cool, that's ordered. |
Thu Oct 01 2015 6:17pm |
