![]() | Home > Technical > Engine Management light on - Advice wanted |
Boost Member Since: 18 Aug 2011 Location: North Lincolnshire Posts: 60 ![]() ![]() ![]() |
For a few weeks I've seemed to have a lack of power when cold compared to normal. i.e. when just gently driving I have had to press the pedal further to make it go. If floored it seems goes as it should.
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 210 ![]() ![]() ![]() |
Could literally be one or more of 1000+ faults. The only way you are going to get a definitive answer to your question is by having the codes read. What you could try, is disconnect the battery and leave it disconnected for around 15 minutes. This should 'reset' the ECU. Then reconnect and try the car again. If the fault is gone, happy days; if it comes back immediately or soon after, then you know it's a genuine fault and not a glitch. Good luck. |
I'm tempted to say you have "Boost issues"... |
Is there a year you cannot blank? I seem to think mine falls into the 'cannot blank' category! Mines a 2007 TDV6
Nope, all can be blanked, but EU4 vehicles (07MY onwards) require an additional software patch to do so. As mentioned, it's normally done as part of a remap (but not essential). I recommend you choose a reputable company like BAS or Alive to provide such. |
Code read today-
Just as I thought. |
I can do the patch with your existing remap. , just not sure when I can get back to Lincs. It may be possible a day next week, but running out of days before I go the Pyrenees for another week after the Les Comes LandRover party on Spain. Bodsys Brake Bible
Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 ![]() |
Can you do a tdv8? spiteful Range Rover Sport tdv8 |
Remap or blank? Or both?
Bodsy,
Yes, you can run it with the Blanks in place. Don't forget to remove the butterfly valve.
EGR's blanked and butterfly valve removed. All OK now and back on song! Even the engine light has gone out and not returned! Does it still need the software patch? |
The light may stay out for ages (or even forever), but equally, could come back on at any time. I believe there is also a very small chance that the fault can still cause restricted power, so best to get it done IMO. |
Nice one Thanks - Ready when you are Bodsy |
