![]() | Home > Technical > Turbo Fault - help needed please! |
Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 ![]() |
Not sure what they mean by sticking, but if your turbos are to be replaced its a body off job, if you can find a local reconditioning place then 100% take them there! Let them know your coming so they can get the parts in advance as to reduce the time it takes them as the car will be stuck on somones ramp until you get them back. Always replace the studs and nuts that hold the manifold to the head as these are prone to failure, I did mime with vauxhall vxr ones as they are much better quality.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4421 ![]() ![]() ![]() |
I've had issues in the past with "reconditioned" turbos on TDV8s.
Cupcake1976
Iv never had trouble with any turbos iv had reconditioned, if the people doing them know what they are doing then they will be fine there's not much to a turbo and even if its beyond repair putting a new cartridge in your housings will basically be a new turbo anyway and still save you more on not buying new ones spiteful Range Rover Sport tdv8 |
Cupcake1976 Member Since: 21 Sep 2015 Location: Shropshire Posts: 3 ![]() ![]() ![]() |
Thank all, I believe the actuator is sticking shut on one side and getting sticky on the other. I am seeing people talking about lubricating them and a mod that come out that keeps it permanently lubricated? Also, I only get slight loss of power which resets the fault if I turn the engine off so will I damage the engine if I keep driving it?
It's not the turbo internals that are the problem, it's calibrating the VNT mechanism.
If you've only had the car 3 weeks why don't you take it back to the seller, even if bought private you have rights, as it is it's not fit for purpose. 2008 G4 RRSport TDV8 current
