Home > General > Towbar hitch receiver poll |
savi18 Member Since: 02 Aug 2015 Location: Gore. South Island NZ Posts: 145 |
Bit reluctant to tow my 2 ton caravan at the moment after reading so many failure's. I have the receiver with the 2 inch square hole which takes the towbar hitch. Not the swan next hitch. The tongue weight is 350kg . can we have a poll on this to see how many members have used this receiver and have had no issues what so ever and how many have failed. It appears a lot have failed due to not being inserted correctly |
Sat Sep 19 2015 8:13pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
"It appears a lot have failed due to not being inserted correctly"
Sun Sep 20 2015 12:56am |
This what I like to hear more positives, no rust here either in NZ, Cheers |
Sun Sep 20 2015 7:20am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Even the swan-necks are absolutely fine when treated properly (removed, greased etc.). Just check it carefully and keep an eye on it, and you should have no reason to worry. Visiting from DISCO3.CO.UK
Sun Sep 20 2015 7:53am |
