Home > Technical > Command Shift operation question on RRS 2012
steve99
I have recently bought a 2012 RRS HSE SDV6. I don't think that the Command Shift is working as it should and wanted some confirmation and resolution advice.
If D is selected when I operate the shift paddle the message 'Command Shift Selected' appears in the message centre and I can use the paddles to change gear up or down. To get it out of this mode I have to pull in the right paddle for 2 seconds. I think that in D the gear selection should revert to automatic without me having to manually do it and that only in sports mode should it remain on.
Can anyone confirm how it should behave - can I do anything or do I need to contact LR?
Thanks
Steve
Post #473183 Mon Sep 14 2015 7:18pm
DrRob
I'm sure paddles are for Sport mode only .....? Might be wrong. Never use them Whistle Visitor from fullfatrr.com
Post #473186 Mon Sep 14 2015 7:25pm
rigsby
You can use the paddles in D or S and as you say hold the + paddle for 2 seconds to return to Auto MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #473191 Mon Sep 14 2015 7:32pm
PEACHY
R(FM8) SEMCON LAND ROVER OWNER GUIDE VER 1.00 EUROLANGUAGE: english-en; MARQUE: landrover; MODEL: L320Gearbox77GearboxAUTOMATIC TRANSMISSION
. With the rotary selector, rotate to D. The paddle shifts can be used in this mode. Gear selection will revert to fully automatic if use of the paddles is not maintained. D will appear in the instrument panel and the LED by the selector will illuminate.3.To select sport mode with the selector lever, move the lever to the left. With the rotary selector, press the selector down and rotate to S. S will appear in the instrument panel and the LED by the selector will illuminate.
As above copied from manual - rigsby beat me too it - I'm loving your new toy - Mr. Green Mr. Green 16MY Estoril Blue SVR.............
Post #473193 Mon Sep 14 2015 7:35pm
steve99
So the manual says 'Gear selection will revert to fully automatic if use of the paddles is not maintained'. I have left it for 30 seconds in the gear selected manually and it doesn't change back to fully automatic. Must be faulty.
I will contact LR.
Thanks
Post #473194 Mon Sep 14 2015 7:39pm
PEACHY
I believe its not timed as such its about the revs used - i might be wrong - my wife kept saying the Sport was over reving - she was catching the paddle by mistake when driving in D - try actualy driving in D after activating paddles - see what happens then - might take a few hundred metres Thumbs Up 16MY Estoril Blue SVR.............
Post #473196 Mon Sep 14 2015 7:43pm
steve99
I will try it tomorrow and report back - thanks.
Post #473197 Mon Sep 14 2015 7:45pm
rigsby
It will change up so as to avoid any unnecessary stress to the engine if you don't change up yourself
Peachy Thumbs Up Thumbs Up MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #473198 Mon Sep 14 2015 7:48pm
steve99
Well it does go back to fully automatic mode if I leave it without manually changing gear. It just takes quite a few more yards than a previous one I drove.
Post #473522 Fri Sep 18 2015 3:51pm
Russben
Mine depends on what you are doing. If driving steadily, it changes back to auto sooner than if I am in traffic & constantly accelerating and decelerating, or if I am going downhill with no throttle applied. I'm in the shed, I'll be back in the real world in a minute.
Post #473524 Fri Sep 18 2015 3:54pm
