Home > Maintenance & Modifications > Fitting resistors to 2010 led rear lights
Morgi27
Hi guys got new led lights today can I get clayification which wires to cut into for soldering the resistor too please
The leds are not Valeo so I'm hoping is the same for these aftermarket lights aswell
Post #472568 Wed Sep 09 2015 2:38pm
Lost for Words
I would recommend you install your resistors inside the car, retaining the integrity of the external wiring to minimise the chance of water ingress. Also, bear in mind, the resistors will heat up, so, wherever you put them, keep them clear from anything they could melt/burn.
You need to connect the resistor to the indicator feed, and to ground. I'm not familiar with the wiring of the RRS clusters (as opposed to D3), but IIRC, the relevant internal wires are green/white (right) and green/red (left).
Thumbs Up Visiting from DISCO3.CO.UK
Post #472570 Wed Sep 09 2015 3:22pm
Morgi27
So is it not safe to glue the resistor just into the back of the light??
Seen this done on videos on you tube and said its fine aslong has use proper ohms resistor which they
Recommended at 15 ohms
Thanks
Post #472572 Wed Sep 09 2015 3:46pm
Lost for Words
I wouldn't want to. I'm sure many do, and over time, some may regret it, but others will get away with it. As I say, it's much better to leave the external wiring intact anyway and keep modifications inside in the dry when possible. Water and salt can spread through wiring like you wouldn't believe - all the way to the ECUs. Thumbs Up Visiting from DISCO3.CO.UK
Post #472578 Wed Sep 09 2015 4:10pm
Morgi27
Thanks for that tip! So I need wire the resistor into the existing wiring on car lights loom and fit resistors onto bodywork inside
Back of light cluster at bottom? Ive seen pics of this on the forum so I'll go this route for safety aswell
Thanks
Post #472581 Wed Sep 09 2015 4:37pm
Bodsy
Site Sponsor
Thanks
The 15ohm resister will get very hot during use. Much better to use a 50 ohms resister. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #472592 Wed Sep 09 2015 5:47pm
SRE
Spain
On my last sport I fitted (glued) 50 ohms resistors with heatsink, from RS Components Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #472596 Wed Sep 09 2015 5:55pm
Morgi27
Has im attaching them to the bodywork not rear of lights does it matter as much to use 50ohm ??
Post #472597 Wed Sep 09 2015 6:06pm
