Home > General (L494) > Speed Limit Display (or lack of it)
iainm
intermittent issue for the past few weeks - thought I'd share with the group as it's not worked all day!!!!
Anyone else had this problem or is it just people in Wayelz!!!! Very Happy
Post #472027 Fri Sep 04 2015 7:17pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
Happens when the Sat Nav has not woken up to its location properly (or the road is new) and the car hasn't passed a sign.
Post #472038 Fri Sep 04 2015 7:49pm
iainm
Thanks for the suggestion Phil, but unless the Nav has narcolepsy; we had driven 9miles!! other times car has been travelling for longer - it never picks up smaller roads like my previous X5 used to
Post #472047 Fri Sep 04 2015 8:32pm
Autobiography
As far as I'm aware, the L405/L494 version is NOT supported by a database and is camera only. InControl Touch on the Evoque and Disco Sport is supported by a nav database. Mine has the --- on the L405 quite frequently. Couple that with the crap HUD, and it's a great way to waste £1600.
Post #472051 Fri Sep 04 2015 8:57pm
philmw
When I turn into my lane (from a 40) the limit changes to 60 without any sign. Must be linked to the Nav.
Occasionally going into a NSL area the display will show the black bar through the while circle sign, but mostly comes up with 60. This also suggests it is linked to the Nav.
And IMHO the HUD is great.
Post #472059 Fri Sep 04 2015 9:27pm
Autobiography
Strange as mine doesn't do that!
And my HUD is barely visible on a clear day because of the reflection. I'm guessing it could be different on the Sport.
Post #472084 Sat Sep 05 2015 8:15am
iainm
All our local roads are rarely picked up; the other half drives it like she stole it, hence why we went for it...waste of £600 me thinks (will ask the dealer when it goes in on the 18th) though would never not have a car without HUD ; I love it.
Mate of mine loves his HUD is X6M
Post #472085 Sat Sep 05 2015 8:18am
philmw
Curious - your 405 is one of the first with the HUD isn't it. Did they fit the solar glass originally (I know they do now)?
Post #472088 Sat Sep 05 2015 8:42am
Autobiography
Yes it was fitted the first week of production. The glass is marked HUD by the Land Rover badge. Is yours?
Post #472111 Sat Sep 05 2015 11:58am
R444SPT
My last RRS2 used to regularly display a "no overtaking sign" on motorways and dual carriageways, as well as random speed limits. Shame because you do quickly get used to it,Mao good for it to be accurate, like the example here, sometimes mid journey it would decide to sho --- as well for no apparent reason.
Post #472201 Sun Sep 06 2015 3:23pm
philmw
Speed limit display is definitely linked to the Sat Nav now: Just drove along a road where the limit has recently changed and the signs moved with the camera taped over and the display changes to show the old limit where the signs used to be. Drove back with the camera uncovered and it shows the new limit.
The display shows --- when on a road where the limit is unknown in the Sat Nav; usually a minor or B-road. I think if you go past a NSL sign from a road where the limit is known by the Sat Nav, it'll display 60 and then change to --- after a short while. If you go past a NSL sign from a road where the limit wasn't know, or was recognised as different from what the Nav thinks it should be, then it'll display the black bar through the while circle NSL sign, and then change to --- after a while.
Yes, my screen does have HUD written on it.
R444SPT - I didn't think the TSR showed anything other than the current speed limit, but have just read the manual and yes it does. Thank you. Never seen the no overtaking sign shown on mine though.
Post #472207 Sun Sep 06 2015 4:30pm
R444SPT
Speed and "no overtaking" showing.....😎
Post #472209 Sun Sep 06 2015 5:12pm
GJW1
The Audi q3 we have shows speed limits for roads on the sat nav display. Is there a way to show speed limits on the sat nav map on the Range Rover also ?
I don't have sign recognition option on the car but if the nav stores the limits then that shouldn't be a factor for the sat nav display ?
Post #472456 Tue Sep 08 2015 8:34pm
terrygill
HI GJW1 I to have an RRS 2016 model without Speed Limit Regcognition and I assumed by ordering the HUD you get the sat nav data displayed somewhere - however I can't find any way to enable it in the system. Going to ask dealer why soon - in the meantime did you get any resolution from anyone?
Post #473322 Tue Sep 15 2015 10:20pm
GJW1
I don't have the HUD I only wanted to see the speed limits for roads on the sat nav map actually but haven't found how to get this info but the manual says you can upload points of interest to the car so if I find the data on google ill give it a try.
As for the HUD its probably in the settings of the car somewhere what to display on the HUD.
Post #473414 Thu Sep 17 2015 11:18am
