Home > General > Hi!!! Help needed |
Ollyhall Member Since: 30 Aug 2015 Location: Portsmouth Posts: 13 |
Anyone? |
Sun Aug 30 2015 7:45pm |
nigel52 Member Since: 20 Nov 2013 Location: Farnham Posts: 274 |
You should find two plastic screws on the rear panel which need a coin to give a half twist to release. You should with luck have the hole ready for detachable tow bar and the electrics already fitted. Fingers crossed. |
Sun Aug 30 2015 7:49pm |
Thanks Nigel , I have the bigger style bumper with the square tail pipes, there's a panel on the bumper how does that come off? I've had problem in past with breaking stuff like this lol |
Sun Aug 30 2015 7:55pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
The receiver is part of the rear crossmember it's standard on all D3's and RRS's all you need is the detachable tow bar unless your going to fit the permanent type. The cover comes off as explained by nigel52. You might be lucky and find its had electrics fitted by a previous owner, if not you can get the wiring kits from a dealer. I think they need to be activated as well but I'm sure there are better informed people on here to put you right about that.. 2008 G4 RRSport TDV8 current
Mon Aug 31 2015 6:50am |
Thanks for the help guys I will take the panel of and take a look |
Mon Aug 31 2015 7:34am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
It's not essential to have them enabled*; they'll work just fine.
Mon Aug 31 2015 8:36am |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 |
@ Ollyhall
Mon Aug 31 2015 12:31pm |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Hen's Teeth 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Mon Aug 31 2015 7:43pm |
No such luck lol |
Tue Sep 01 2015 6:42pm |
