![]() | Home > Technical > Rear windows not working |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
Sorry to state the obvious- but you haven't got the overide selected gave you? Not sure that inhibits both sets of switches but might be worth recycling. |
RRSTDV8DK Member Since: 26 Mar 2007 Location: cph Posts: 67 ![]() ![]() ![]() |
if only |
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 ![]() |
And you didn't check the relay! |
And you didn't read my initial post? I don't know where the relay is, so I asked if anybody knows that?
if you found the fuses, you should have seen the relay R143
I assume the front ones are working, or you'd have mentioned them? If they're fine, it's not going to be the relay, since it's used by all four. The same goes for FL18 in the BJB. |
"I assume the front ones are working, or you'd have mentioned them? If they're fine, it's not going to be the relay, since it's used by all four. The same goes for FL18 in the BJB. Wink"
A very good morning to you, sir.
I am sorry that you feel it necessary to take the offensive stance, as this forum is a generally pleasant and hospitable place to be, and takes no gain from ill-considered discourteous posting. Perhaps, in future, you might consider giving a little more thought before taking to discrediting members on a whim. Kind regards, LFW Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Well I am happy to see where you got that information from as the official LR RRS wiring diagram (501-11) I got it from and which I posted is showing that only the rear windows go through that relay!
Sorry, I owe you an apology, having re-checked, you are correct about the relay. |
BTW, just to add, your picture wasn't showing up for me initially. |
Thank you
I have not had the time (or courage) to look at it - but I was thinking if it may just be easier to replace the CJB?
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
I just replaced the CJB in mine due to the horn not working! I had to buy a new one from the main stealer at £330.00 plus VAT it had to be coded by Land Rover to my car's VIN before they sent it out.
