Home > Technical > Rear windows not working
RRSTDV8DK
Denmark 2007 Range Rover Sport TDV8 HSE Stornoway Grey
On my TDV8 2007 the rear windows stopped working. They are not responding from the drivers side controls or from the individual controls on the rear doors.
It looks like they have individual fuses (13 and 17 in the glove department fuse box) so I guess it is not a fuse issue since they both stopped working at the same time.
So I'm thinking a faulty relay - but where do I find the relay for the rear windows? Or is it something else? RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #469663 Thu Aug 06 2015 9:10am
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Sorry to state the obvious- but you haven't got the overide selected gave you? Not sure that inhibits both sets of switches but might be worth recycling.
Post #470300 Thu Aug 13 2015 7:17pm
RRSTDV8DK
if only Smile
Checked all switches, overrider, fuses - all looking good RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #470339 Fri Aug 14 2015 9:16am
jochem00
And you didn't check the relay!
Post #470502 Mon Aug 17 2015 9:34am
RRSTDV8DK
And you didn't read my initial post? I don't know where the relay is, so I asked if anybody knows that?
but it might be more complicated that just a relay - http://www.disco3.co.uk/forum/topic103185....ws+working RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #470547 Mon Aug 17 2015 2:32pm
jochem00
if you found the fuses, you should have seen the relay R143
it is in the CJB
Did you check if you get 12v at fuses 17 and 31? or did you pull out the fuses and just checked that they are OK?
check if you get 12v there! if no power, check the big fuse 18E in the engine compartment's battery junction box.
if that fuse is OK, then it must be the relay.
( if power at the small fuses 17 and 31, then you must have a wiring problem and you should have a look at the wires in the footwell.)
Post #470551 Mon Aug 17 2015 3:01pm
Lost for Words
I assume the front ones are working, or you'd have mentioned them? If they're fine, it's not going to be the relay, since it's used by all four. The same goes for FL18 in the BJB. Wink Visiting from DISCO3.CO.UK
Post #470552 Mon Aug 17 2015 3:22pm
jochem00
"I assume the front ones are working, or you'd have mentioned them? If they're fine, it's not going to be the relay, since it's used by all four. The same goes for FL18 in the BJB. Wink"
Well you obviously didn't check the wiring diagram and are just writing something without knowing for sure!! Rolling with laughter Rolling with laughter Rolling with laughter
So please don't post any grap like that!
Post #470608 Tue Aug 18 2015 7:28am
Lost for Words
A very good morning to you, sir.
I can only assume that at some point in your investigation you have been subject to an unfortunate error, as you will, I believe, find, that I am, in fact, correct and have indeed consulted wiring diagrams.
Quote:
Glass Frames and Mechanisms - Description and Operation...
Electric windows are installed in all four doors. The drivers front window incorporates a self-contained 'Anti-trap' regulator, which features one-shot up and one-shot down functionality. All the passenger windows are hard wired and are powered via the window lift relay in the Central Junction Box (CJB).
I am sorry that you feel it necessary to take the offensive stance, as this forum is a generally pleasant and hospitable place to be, and takes no gain from ill-considered discourteous posting. Perhaps, in future, you might consider giving a little more thought before taking to discrediting members on a whim.
Kind regards,
LFW Visiting from DISCO3.CO.UK
Post #470615 Tue Aug 18 2015 8:12am
jochem00
Well I am happy to see where you got that information from as the official LR RRS wiring diagram (501-11) I got it from and which I posted is showing that only the rear windows go through that relay!
So please show your source of info as I have been factual so far.
Post #470617 Tue Aug 18 2015 8:21am
Lost for Words
Sorry, I owe you an apology, having re-checked, you are correct about the relay. Thumbs Up
When I say I checked the wiring diagram, I did, with reference to FL18, which is shared by all - perhaps your comment was not intended to encompass this, as I took it to? I had not checked the relay properly, having read the wording in the Description and Operation section, as posted, and a previous comment from member "Robbie". This is obviously a mistake that LR have made with their use of the word "passenger". Rolling Eyes
As I say, apologies for the confusion, but next time you need only question politely, as mistakes happen, even in LR's documentation. Visiting from DISCO3.CO.UK
Post #470619 Tue Aug 18 2015 8:51am
Lost for Words
BTW, just to add, your picture wasn't showing up for me initially. Thumbs Up Visiting from DISCO3.CO.UK
Post #470628 Tue Aug 18 2015 9:23am
RRSTDV8DK
Thank you
I will check as soon as I have the time RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #470650 Tue Aug 18 2015 11:26am
RRSTDV8DK
I have not had the time (or courage) to look at it - but I was thinking if it may just be easier to replace the CJB?
If so, is this the right one? http://www.ebay.co.uk/itm/Range-Rover-L322...SwQItUK~BR RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #480853 Wed Nov 25 2015 8:36am
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
I just replaced the CJB in mine due to the horn not working! I had to buy a new one from the main stealer at £330.00 plus VAT it had to be coded by Land Rover to my car's VIN before they sent it out.
Good luck..
Post #480857 Wed Nov 25 2015 11:06am
