![]() | Home > General > Petrol in a TDV6 |
Nope. TDV6 will just keep driving until it stops
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
What year is your car? The facelifted car (end of 2009 onwards) has a misfuel device. I once put the petrol nozzle in mine and it shut a flap in the filler after I had put about 50 pence in it. There is a tool in the boot to reset it, I then brimmed it with diesel and all was fine!
Dan Stevens Member Since: 19 Aug 2013 Location: Brisbane Posts: 47 ![]() ![]() ![]() |
Mines an 07 model.
A friend has an 07 D3 and filled with petrol - the car drove off and shortly after the dashboard lit up like a christmas tree and very very shortly after the engine shut down.
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
Same here but only once! I felt a bit of a prat walking to the counter, "pump 3" .... "47p, please, sir".... "Do you take Amex?" ![]() RRS TDV6 HSE Lux (MY2011)... Nara Bronze / Arabica - now gone! |
tonyninety Member Since: 04 May 2015 Location: norwich Posts: 11 ![]() ![]() ![]() |
Yes I did the same on my 13 plate RRS and as soon as it had started it stopped very soon and it was then that I realised that it was petrol that I was putting in.I then changed to diesel and filled the tank as it was nearly empty annd found out that I had put in about 50p worth and did not worry as it was drowned by the diesel.At no time did I have to use the yellow misfuel key. |
