Home > Technical > Will it fit in my garage? |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
I think it will fit i remember seeing a pic from RRUK he has his in his garage RRS TDV6 Gone but still around
Fri Jul 28 2006 8:29am |
Ronnie in the Midlands Member Since: 18 Jun 2006 Location: Hertfordhsire Posts: 50 |
I think thats why I sent the post. I saw the pic as well and thought maybe it will fit. I just take it as red that it wouldn't fit. New RRS |
Fri Jul 28 2006 8:38am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Ronnie - Not that mine has been in the garage but I did line it up outside out of interest and as I recall clear on height but width looked borderline even with mirrors folded - dont think I risk the risk of damage. This is in a new ish build good sized double garage - I have thought about custom double door down the line with new lintel and perhaps auto open'er but I doubt I'd garage it then.... I guess the dimensions will be online somewhere for you to verify. I know at the last house I had garage built with 7'x7' door (as i recall) for this type of vehicle but moved before had chance to use it ! |
Fri Jul 28 2006 8:39am |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 |
It should fit but my only word of caution is that my house was built back in '88. Since then builders don't seem to make garages as big, my friend has a modern house and the garage is not big enough to get a VW Polo in, not joking. They assume that you only want to keep bikes and 'stuff' in it. I'd advise you measure you garage and take into account caopy door shut lines etc.
Fri Jul 28 2006 8:53am |
My build was '01 they haven't scrimped on the floorspace just the doors!?!?! Ridiculous for the £100 or £200 [more] decent doors would have been... |
Fri Jul 28 2006 8:59am |
tonser Member Since: 17 Jan 2006 Location: Cobham, Surrey Posts: 244 |
Heres the RRS dimensions from the brochure:
Fri Jul 28 2006 9:32am |
Hmm which equates to 77.95" a shade under 6'6" and I think standard garage doors are 6'6" - 1.27mm clearance !! - just not enough not to spoil your day is it - down to the builder at the end of the day and what doors were fitted then. |
Fri Jul 28 2006 9:44am |
kam100 Member Since: 28 Sep 2005 Location: In my office doing quotes!! Posts: 4771 |
Hi Ronnie.
The RRS only just fits into my garage and even then it has to be reversed in because I wouldn't be able to open the doors to get out if I drove in frontways. To that end, I don't normally put it in unless we're going to be away for a while...
Fri Jul 28 2006 10:32am |
I've managed to get a full size RR in ours despite it being a very tight squeeze.
Fri Jul 28 2006 11:27am |
In the spirit of helpful suggestions, you could knock down your garage and have it rebuilt such that it fits perfectly!
Fri Jul 28 2006 11:29am |
That's a good idea Shmoogle RRS TDV6 Gone but still around
Fri Jul 28 2006 11:33am |
I thought so!
Fri Jul 28 2006 11:35am |
Fri Jul 28 2006 11:36am |
