Home > Technical > Will it fit in my garage?
Page 1 of 3 123>
Ronnie in the Midlands
Any one know if my new RRS will fit in a standard double garge (two single doors), it's a standard build that's the usual size with all new houses. I guess I'm concerned it maybe too tall or wide? What's the view? New RRS
Post #46987 Fri Jul 28 2006 8:24am
I think it will fit i remember seeing a pic from RRUK he has his in his garage RRS TDV6 Gone but still around
Post #46989 Fri Jul 28 2006 8:29am
I think thats why I sent the post. I saw the pic as well and thought maybe it will fit. I just take it as red that it wouldn't fit. New RRS
Post #46993 Fri Jul 28 2006 8:38am
MAW
Re: Will it fit in my garage?
Ronnie - Not that mine has been in the garage but I did line it up outside out of interest and as I recall clear on height but width looked borderline even with mirrors folded - dont think I risk the risk of damage. This is in a new ish build good sized double garage - I have thought about custom double door down the line with new lintel and perhaps auto open'er but I doubt I'd garage it then.... I guess the dimensions will be online somewhere for you to verify. I know at the last house I had garage built with 7'x7' door (as i recall) for this type of vehicle but moved before had chance to use it !
Post #46994 Fri Jul 28 2006 8:39am
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
It should fit but my only word of caution is that my house was built back in '88. Since then builders don't seem to make garages as big, my friend has a modern house and the garage is not big enough to get a VW Polo in, not joking. They assume that you only want to keep bikes and 'stuff' in it. I'd advise you measure you garage and take into account caopy door shut lines etc.
I replaced our canopy doors with 2 fully electric roller doors, they are a godsend and look nice too in dark green. Wasn't cheap mind you.
I also have to fold the mirrors in to get the car in and out. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #46995 Fri Jul 28 2006 8:53am
MAW
My build was '01 they haven't scrimped on the floorspace just the doors!?!?! Ridiculous for the £100 or £200 [more] decent doors would have been...
Post #46996 Fri Jul 28 2006 8:59am
tonser
Heres the RRS dimensions from the brochure:
Standard Mode height: 1812mm
Access Mode Height: 1762mm
Length: 4788mm
Width (mirrors in) : 1983mm
Width (mirrors out) : 2170mm
Tonse Play: '59 VW Kabrio & '90 964
Work: http://www.mustardpost.com
Post #47000 Fri Jul 28 2006 9:32am
MAW
Hmm which equates to 77.95" a shade under 6'6" and I think standard garage doors are 6'6" - 1.27mm clearance !! - just not enough not to spoil your day is it - down to the builder at the end of the day and what doors were fitted then.
Post #47001 Fri Jul 28 2006 9:44am
kam100
Hi Ronnie.
We live in a David Wilson Home, built around 95 mark.
It has standard size cardale canopy garage doors, and although i never tried to get my RRS fully into the garage, i remember when i was fiddling with something in the engine bay, i managed to get the car in width ways. It didn't look like it would fit length ways though.
I can get my RS4 fully in, with about a ft clear, but no chance with my dads old 7 series or the A8. Guess you will have to get your measuring tape out. Although garages should be standard size, builders often chop and change garage sizes to suit the rest of the property.
Where abouts are you in the midlands? another one for a midlands mini meet then guys..
Post #47002 Fri Jul 28 2006 9:44am
The RRS only just fits into my garage and even then it has to be reversed in because I wouldn't be able to open the doors to get out if I drove in frontways. To that end, I don't normally put it in unless we're going to be away for a while...
Post #47005 Fri Jul 28 2006 10:32am
RRUK
I've managed to get a full size RR in ours despite it being a very tight squeeze.
(Sorry I know it doesn't help!) L319 D4 HSE
1982 Series 3 SWB
Post #47015 Fri Jul 28 2006 11:27am
In the spirit of helpful suggestions, you could knock down your garage and have it rebuilt such that it fits perfectly! Thumbs Up
Post #47017 Fri Jul 28 2006 11:29am
That's a good idea Shmoogle RRS TDV6 Gone but still around
Post #47019 Fri Jul 28 2006 11:33am
I thought so! Idea Thumbs Up
Post #47021 Fri Jul 28 2006 11:35am
Laughing Wink RRS TDV6 Gone but still around
Post #47023 Fri Jul 28 2006 11:36am
Page 1 of 3 123>
