Home > Faults & Fixes > front and rear parking sensors not working |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 |
Seems to be an easy to happen thing, check the front bumper wires first as they seem to show water is an issue in there on the cables just find and patch em. worst case buy a new sensor. But they are not expensive. |
Sun Jun 08 2014 9:44pm |
robbietdv8 Member Since: 19 May 2015 Location: Blandford Posts: 6 |
hey i have the same fault with my 2007 sport , checked all the sensors none tick, light on dash flashes.get a beep from rear when in reverse
Wed May 27 2015 4:49pm |
Paszko Member Since: 27 Jun 2011 Location: Halifax Posts: 18 |
Hi, still searching! Haven't had the time to take off the bumper to check.
Wed May 27 2015 4:56pm |
you got it 2007 HSE sport, grey on black 20inch black alloys.
Wed May 27 2015 5:03pm |
seankenyon Member Since: 21 Jul 2014 Location: Warrington, Cheshire Posts: 35 |
Ive got the same problem and fault codes diagnosed on my Hawkeye diagnostics, took me less than half an hour to take the front bumper off, checked all the wiring and connections with no signs of water ingress or broken wires, even used a Decibel App on my phone with ignition to position one and the gear in drive & reverse and checked all PDC Sensors but its not obvious if they are working or not, difficult to hear if there is any clicking
Fri May 29 2015 8:43am |
I managed to fix the problem, ordered a used PDC Module from America £45 Inc postage
Tue Jul 28 2015 5:35pm |
goolraul Member Since: 04 Dec 2015 Location: toronto Posts: 4 |
have the same codes for front and rear sensors.
Fri Dec 04 2015 2:39am |
I replaced the rear loom as it was corroded in a few spots behind the bumper, only accessible by taking the bumper off, the rear bumper is easier to remove than the front |
Fri Dec 04 2015 7:43am |
I'll have a look at the rear loom this weekend 😊
Fri Dec 04 2015 9:25am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Had this issue and same codes on our D4, yesterday in fact.
Fri Dec 04 2015 12:42pm |
Thanks for the input I wil let you know what I find.... |
Fri Dec 04 2015 12:54pm |
After a long winter i spent the weekend pulling both the front and rear bumpers. wiring is in tact and did a resistance check on every wire to double check. found nothing
Sun Apr 17 2016 2:58am |
Johnsurrey Member Since: 07 Apr 2016 Location: Tadworth Posts: 44 |
Hi , Iv got the same problem , replaced the rear loom made no difference maybe the moduel next ? Or would it be worth doing the front first ? |
Mon Jun 20 2016 9:06pm |
