![]() | Home > Maintenance & Modifications > 2005 air suspension fault |
Front valve block maybe. Try a search on here. Others might comment soon.... Visitor from fullfatrr.com
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
i reckon you have a leak somewhere hence the reason the compressor was overworking ,get some leak detector spray and spray all airbags and air lines ,i have had 2 leaking rear air bag pipe connectors in past |
AKA soapy water. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Or get a good independent LR service place to look at it.........Rovertune in Reading is the best in these parts....but not sure about Kent area...... Visitor from fullfatrr.com
w55ksy Member Since: 05 Feb 2015 Location: Bromley Posts: 7 ![]() ![]() ![]() |
Hi Daz,
Chris80 Member Since: 05 Oct 2015 Location: Kent Posts: 58 ![]() ![]() ![]() |
Hello Chris,
Hi Chris80, well not quite yet. I kind of left it over Christmas. Funny enough though, I did have a good look yesterday and found a blown fuse. It is a tall yellow box shaped 60 amp fuse in the main fuse box next to the battery. I think it was fuse 10.
Be great if you could keep me posted |
