Home > Maintenance & Modifications > 2005 air suspension fault
Daz3112
United Kingdom 2005 Range Rover Sport 3.0 TDV6 HSE Java Black
I have recently had the suspension fault coming up on my 2005 RRS, this stopped happening but the compressor has started to run constantly and when you lift from access height to normal or from normal to off road the rear raises just as it should but the front is really slow to reach height, I was advised to change the compressor as it was more than likely on its way out so I changed the compressor and relay tidy but I still have the problems. Is anyone able to point me in the right direction as to what else could cause this.
Post #468728 Mon Jul 27 2015 7:26pm
DrRob
Front valve block maybe. Try a search on here. Others might comment soon.... Visitor from fullfatrr.com
Post #468759 Mon Jul 27 2015 8:44pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
i reckon you have a leak somewhere hence the reason the compressor was overworking ,get some leak detector spray and spray all airbags and air lines ,i have had 2 leaking rear air bag pipe connectors in past Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #468760 Mon Jul 27 2015 8:53pm
Lost for Words
Quote:
leak detector spray
AKA soapy water. Laughing Visiting from DISCO3.CO.UK
Post #468805 Tue Jul 28 2015 8:31am
DrRob
Or get a good independent LR service place to look at it.........Rovertune in Reading is the best in these parts....but not sure about Kent area...... Visitor from fullfatrr.com
Post #468823 Tue Jul 28 2015 11:59am
w55ksy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
What's the answer?
Hi Daz,
I have exactly the same symptoms as yours. Suspension Fault warning on dash. The problem came on quite suddenly - no issues before. Back of car raises fine, but front raises very, very slowly - then says pump is overheating.
I have had the pump replaced at �500, but still exactly the same. Did you get yours fixed? If so do you know what the cause was? I'd be really grateful for any pointers.
Regards,
Chris 07956 786622
Post #482059 Wed Dec 09 2015 7:59pm
Chris80
United Kingdom 2008 Range Rover Sport TDV8 HST Stornoway Grey
Hello Chris,
Did you sort your problem, as I have the same?
Just waiting for my IID tool to turn up to read the codes on it.
Cheers Chris Thumbs Up
Post #483993 Mon Jan 04 2016 3:35pm
w55ksy
Hi Chris80, well not quite yet. I kind of left it over Christmas. Funny enough though, I did have a good look yesterday and found a blown fuse. It is a tall yellow box shaped 60 amp fuse in the main fuse box next to the battery. I think it was fuse 10.
I have ordered another one �5 going to swap that before I take further action. Car is stuck in "normal ride height" so perfectly useable. Will keep you posted.
Post #484004 Mon Jan 04 2016 6:39pm
Chris80
Be great if you could keep me posted Thumbs Up
Been told that my IID tool isn't going to be dispatched until Wednesday now because of the back log after Christmas!.
Did you have the codes read on yours? Can't use mine as only the rear is rising out of access mode!. Going to try to have a look tomorrow for anything obvious whilst I'm waiting.
Chris Thumbs Up
Post #484006 Mon Jan 04 2016 6:46pm
