![]() | Home > General > Engine System Fault and Black Smoke |
RossM Member Since: 27 Aug 2012 Location: Poulton-Le-Fylde, Lancashire Posts: 80 ![]() ![]() ![]() |
Started to get "Engine System Fault" on the dash and also getting excess black smoke on acceleration and noticing that there is definetley a delay in acceleration. Any ideas? I'm wondering if it's a split pipe or something. 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
Most likely a split hose, the one right at the front of the engine bay, left hand side as you look at it |
Cheers Disc Mikey, will have a look when it stops raining! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
I'll check back on Thursday |
Found it! Now I can see this end, where is the other and how hard is it to get to? Anyone know the part number?
PNH500025
Is the bottom of the hose accessed through the plastic cover in the right hand wheel arch? 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
Yes. |
Cheers Guys, I did this job a couple of weeks ago, nice and easy to swap the pipe for new one. The old pipe was quite ganged up which I wasn't expecting! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
