Home > Technical > Default Audio volume
At level 7 I can't hear mine when the car is moving... and at 20 it's VERY LOUD INDEED!! At 90mph, I have it set to 15 and move it down to 13 for town traffic.
Might be useful to someone. Not sure who... Wink
Post #46737 Wed Jul 26 2006 8:04am
Lateral5
Australia
Mine is just a bit too loud (particularly in the morning when my ears are sensitive! Evil or Very Mad ) at 7 and I usually turn it down to 5. I guess the bottom line is.....it would be nice if it could stay at your last setting, as does every other car I have ever had!
Mr LR technicians......what's you take? RRS TDV6 Bluetooth, VR, Roof
Post #46779 Wed Jul 26 2006 12:48pm
Hmm... maybe the calibration is different for the Oz market?
Post #46780 Wed Jul 26 2006 12:52pm
Lateral5
Australia
There may also be some difference between the standard system and the Premium ICE number.....amps, speakers etc. Mine is your bog standard model. RRS TDV6 Bluetooth, VR, Roof
Post #46781 Wed Jul 26 2006 1:01pm
PaulB
Zipperman19 wrote:
Is your volume number between 7 and 20 beacause if so, it will come back on at the correct volume. Try putting it to 25 or 5 and see what it comes back on as.
I tried this and you're right. If I set it to 6 and then turn it off and on again, it resets to 7. Similarly, if if set it to 21, it will turn back on at 20. Anywhere between 7 and 20 and it will come back on at the same level as it was turned off at.
Mine is the premium ICE, but not Logic 7.
Paul
Post #46835 Wed Jul 26 2006 8:33pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Something that bothers me about the volume is that if you have a DVD playing through the RSE system, or an iPod or other player connected through the AUX socket, setting the volume level at 20 sort-of equals maybe a 10 with other sources (radio and CDs), so of course you crank it up to 25-30 to hear it properly... But if the navigation lady suddently chimes in with her instructions at that volume level, she blows your eardrums away, and offsetting the nav volume level while using the DVD or AUX inputs does not "stick", either. Sad It's annoying to say the least, and an inconsistecy that I hope Land Rover will fix in 2007MY.
Post #46838 Wed Jul 26 2006 10:25pm
thats the downside of extended battery lives of Ipods and other portable equipment - you just sacrifice the line level voltage output. We have so many problems with our installs with Ipods - they can be a right pain!!
Post #46852 Thu Jul 27 2006 8:47am
Black Sea
Romania 2006 Range Rover Sport TDV6 SE Java Black
How can you modify the limits of 7 and 20? 2006 Range Rover Sport TDV6 SE Java Black
Post #46855 Thu Jul 27 2006 9:19am
PaulB
Why would you want to ? Do you really want to save volume settings of lower than 7 or higher than 20 ?
Post #46857 Thu Jul 27 2006 9:25am
Black Sea
I want to save volume settings of lower than 7. Thank you in advance. 2006 Range Rover Sport TDV6 SE Java Black
Post #46861 Thu Jul 27 2006 9:45am
PaulB
Do you have the standard ICE or the Premium ICE ?
Post #46872 Thu Jul 27 2006 11:22am
