Home > Faults & Fixes > gearbox slipping
austencameron
gearbox slipping
any sugestions on where to buy a recon box from?
Post #467179 Fri Jul 10 2015 9:56pm
Bodsy
Site Sponsor
It's probably the torque converter rather than the auto box.
Bristol transmissions charge about £450 for a TC, then y need to get fitted of course. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #467180 Fri Jul 10 2015 10:07pm
Disco_Mikey
Direct from LR is your best bet. Facotry recon unit, all done by ZF.
Just had to replace the box on my Disco
Not cheap, but it's going to be right.
And when it's in bits, check the input splines of the transfer box. That was another sore one, on top of an already expensive job Big Cry
Post #467181 Fri Jul 10 2015 10:31pm
Does worn splines on the transfer box mean a new box or is it a "strip and fix" job? 2012 SDV6 - it's missing a couple of cylinders
Post #467192 Sat Jul 11 2015 8:27am
Disco_Mikey
They can be repaired, but it is a bit of a specialist job, setting up bearing preloads etc.
Post #467195 Sat Jul 11 2015 8:46am
Ah, so a new box then really. Wow, that's going to become a pricey little game quite quickly... 2012 SDV6 - it's missing a couple of cylinders
Post #467205 Sat Jul 11 2015 11:57am
Disco_Mikey
Yup. Mine has just swallowed £4.5K (+ VAT) in the last 3 weeks Big Cry
It's only money, can't take it with you Rolling Eyes
Post #467211 Sat Jul 11 2015 2:21pm
Is that with your labour in for free?! Shocked 2012 SDV6 - it's missing a couple of cylinders
Post #467214 Sat Jul 11 2015 3:05pm
Disco_Mikey
Yup Rolling Eyes
Post #467218 Sat Jul 11 2015 3:37pm
Williamsboy
Wales 2005 Range Rover Sport TDV6 HSE Rimini Red
Hi guys sorry to hear about gearbox slipping. My 2005 rrs in currently in the garage having a new gearbox fitted. £3000 bill paid upfront but I get 2 yr unlimited mileage warranty and piece of mind. Just a bit fed up waiting to get the rrs back, having to drive around in my daughters Peugeot 107. Not the most comfortable of drives etc, but better a 2nd class drive than a 1st class walk.
Hope u get yours sorted rrstdv8, mine had a similar problem. Slipping and going in to fault mode.
Regards
Mike
Post #467447 Mon Jul 13 2015 10:48pm
