Home > In Car Electronics > Satnav does not locate the car properly |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
I believe the system uses both the GPS and wheel sensors, which explains why there is the red line across the GPS icon but the screen somehow shows the proper position for a couple of hours after recalibration. Eventually it starts showing a different location, some 20 miles away from where I actually am. I've read a new GPS antenna might be a fix, but I didn't find any procedure for satnav diagnostics. Anyone with a similar experience and a solution? TIA. Regards etc.,
Sun Jul 05 2015 8:25pm |
So do you have an abs problem as well? It won't recalculate driving routes without abs speed info. Search for USB GPS for replacement GPS signal info if it is the problem. Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
Sun Jul 05 2015 10:30pm |
No, the ABS is all OK (DSC etc as well). I actually didn't put any route into it to calculate, I just use the map view.
Mon Jul 06 2015 10:26am |
Mr Messy Member Since: 14 Jun 2015 Location: Reading Posts: 22 |
I had this very problem. New gps antenna fitted into the sharks fin fixed it. There is a write up on how to fix it. £8 antenna from eBay, 10 mm spanner and a number 8 torx bit should be all you need. |
Mon Jul 06 2015 12:34pm |
Great, I'm going hunting for the antenna then. Thanks. Regards etc.,
Mon Jul 06 2015 12:53pm |
http://www.rrsport.co.uk/forum/topic32826....ps+antenna
Mon Jul 06 2015 12:56pm |
Mon Jul 06 2015 1:00pm |
Great, that's some great stuff. Many thanks. Regards etc.,
Mon Jul 06 2015 1:40pm |
Quick update - problem solved with an aftermarket GPS antenna (costs around 6 quid where I live). The actual culprit was a broken cable that fell out the Fakra GPS antenna connector under the headliner. Thanks for all your help and input, much appreciated. Regards etc.,
Sat Jul 18 2015 12:58pm |
Sat Jul 18 2015 5:43pm |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 |
Just to revive this thread out of many.
Sun Mar 26 2017 2:56pm |
I'm afraid it's USB for a reason Regards etc.,
Sun Mar 26 2017 8:52pm |
ok, so need to go and find a normal gps antenna. |
Mon Mar 27 2017 10:30am |
