![]() | Home > General (L494) > ARC Valve Block |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1677 ![]() ![]() ![]() |
I believe there is a valve that controls the flow of hydraulic fluid between the left and right front roll bars to counteract the rolling when cornering. This valve can stick (happened in my last Sport) and when does the active roll control stops working, giving rise to a warning message on the dash. You certainly notice the difference in handling too. |
JSR2014 Member Since: 10 Feb 2015 Location: Kent Posts: 341 ![]() ![]() ![]() |
Thank you.
Also,
Haven't noticed this recently (although not had the car much recently) but I know on my old Sport's the engine made a different sound, almost as if there was a fan running, when started from cold. I wodner whether there is an air-feed into the exhaust on start-up to reduce emissions, and this has stuck open?
I was thinking of giving it one more tank to see if the consumption will settle back to where it needs to be, and then if not it sounds like its back to the dealers.
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 ![]() ![]() |
I'm interested that you only put 75 litres or so in at a time. Is this because you stop for fuel as soon as the fuel level low warning comes on? The tank capacity is 105 litres but even if I let it run until the range is close to zero, I've never managed to put more than 90 litres in at a time which suggests the fuel gauge is very pessimistic. Interesting that fuel is so expensive in your part of the world too or maybe you use motorway service areas!
Hi Mark,
Looks like it was a learning issue, economy seems to have gone back to normal!
