Home > Maintenance & Modifications > Front suspension creaking
lugzyboy82
England 2007 Range Rover Sport TDV6 HSE Java Black
Hi there
I have a range rover sport 07 and the front end of the car creaks like mad when going over the slightest bump. I cant seem to pin point the affected area.
First thoughts were that this would be a suspension issue but a friend mentioned that it could be a problem with the roll bar???
Has anybody experienced this and is it an easy fix?
Thanks
Post #466105 Tue Jun 30 2015 8:46am
aljo
common problem is the anti roll bar bushes Thumbs Up and easy enough done
Post #466172 Tue Jun 30 2015 6:17pm
tone 123
England 2005 Range Rover Sport Supercharged Java Black
as aljo said 99% sure anti roll bar bushes about £25. you could have a go yourself. plenty of info on here on how to do.
Post #466189 Tue Jun 30 2015 8:56pm
lugzyboy82
Brilliant. Thanks a lot. Is it just the bushes or will I need to change the rods as well???
Post #466193 Tue Jun 30 2015 9:25pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Thats assuming that the ARB is not ACE.If it is, its very dificult to get a spanner on the back bolts Big Cry itisme
Post #466209 Wed Jul 01 2015 7:17am
tone 123
hi. the best way is wd40 bolts the day before ace arb arms are a lot harder
Post #466278 Wed Jul 01 2015 8:15pm
lugzyboy82
Hi guys, hi do I know if it's an ACE vehicle?
Post #466442 Fri Jul 03 2015 4:34pm
lugzyboy82
Well it looks like my vehicle does have ACE as I have an additional reservoir under the bonnet showing the car Brady with an arrow either side. Is this going to be one of those jobs where a require a special tool???
Post #466443 Fri Jul 03 2015 4:41pm
lugzyboy82
Got to love this predictive text on I-phone. Pretty sure the last message will make sense.
Post #466444 Fri Jul 03 2015 4:42pm
tone 123
no special tool just awkward to get the spanner in mate. and you can only turn the back bolt a little bit at a time.
Post #466552 Sat Jul 04 2015 9:39pm
lugzyboy82
This is a new one on me. I checked the pressure on my near side front tyre and it was low compared to the off side. Inflated so both tyres were the same and the creaking has completely stopped. Happy days. Just the knock from the rear axle which I presume is the rear arb bushes.
Post #466594 Sun Jul 05 2015 2:02pm
DrRob
I foo*in love Land Rovers for this sort of stuff Rolling with laughter
On holiday with my 200Tdi Classic (a proper Rangie) and I hear a belt squeak. Bit of Fairy liquid on it and it's gone - for a while anyway Rolling with laughter Rolling with laughter Visitor from fullfatrr.com
Post #466597 Sun Jul 05 2015 2:59pm
Jeep948
Scotland
I am having the same problem and want to replace my ARB's to see if resolves, how would I know if it was ACE? Thanks in advance Thumbs Up
Post #467813 Fri Jul 17 2015 11:57am
DrRob
Age and spec of your car? Visitor from fullfatrr.com
Post #468092 Mon Jul 20 2015 5:44pm
Jeep948
Scotland
2006 RRS Supercharged
Post #468097 Mon Jul 20 2015 6:12pm
