Home > Maintenance & Modifications > Front suspension creaking |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 |
common problem is the anti roll bar bushes and easy enough done |
Tue Jun 30 2015 6:17pm |
tone 123 Member Since: 18 Dec 2014 Location: northeast Posts: 36 |
as aljo said 99% sure anti roll bar bushes about £25. you could have a go yourself. plenty of info on here on how to do. |
Tue Jun 30 2015 8:56pm |
lugzyboy82 Member Since: 30 Apr 2015 Location: Cheshire Posts: 26 |
Brilliant. Thanks a lot. Is it just the bushes or will I need to change the rods as well??? |
Tue Jun 30 2015 9:25pm |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
Thats assuming that the ARB is not ACE.If it is, its very dificult to get a spanner on the back bolts itisme |
Wed Jul 01 2015 7:17am |
hi. the best way is wd40 bolts the day before ace arb arms are a lot harder |
Wed Jul 01 2015 8:15pm |
Hi guys, hi do I know if it's an ACE vehicle? |
Fri Jul 03 2015 4:34pm |
Well it looks like my vehicle does have ACE as I have an additional reservoir under the bonnet showing the car Brady with an arrow either side. Is this going to be one of those jobs where a require a special tool??? |
Fri Jul 03 2015 4:41pm |
Got to love this predictive text on I-phone. Pretty sure the last message will make sense. |
Fri Jul 03 2015 4:42pm |
no special tool just awkward to get the spanner in mate. and you can only turn the back bolt a little bit at a time. |
Sat Jul 04 2015 9:39pm |
This is a new one on me. I checked the pressure on my near side front tyre and it was low compared to the off side. Inflated so both tyres were the same and the creaking has completely stopped. Happy days. Just the knock from the rear axle which I presume is the rear arb bushes. |
Sun Jul 05 2015 2:02pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
I foo*in love Land Rovers for this sort of stuff
Sun Jul 05 2015 2:59pm |
Jeep948 Member Since: 17 Jul 2015 Location: Scottish Borders Posts: 8 |
I am having the same problem and want to replace my ARB's to see if resolves, how would I know if it was ACE? Thanks in advance |
Fri Jul 17 2015 11:57am |
Age and spec of your car? Visitor from fullfatrr.com
Mon Jul 20 2015 5:44pm |
2006 RRS Supercharged |
Mon Jul 20 2015 6:12pm |
