Home > Faults & Fixes > Flat Battery
wings21660
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Fuji White
Flat Battery
Took the caravan away at the weekend and blew up my daughters air beds for her, but I must have over done it. The battery went flat, so I got the car jump started & gave it a run I thought everything was fine until coming home on the monday & the two lights on the right came on & twenty seconds later the third light came on. The faults were HDC fault followed by a Transmission fault. I am hoping someone out there might be able to help with the problem.Is it all to do with the flat battery?.
Bow down
Post #465822 Fri Jun 26 2015 3:20pm
tanloverluke
when the battery is flat or nearly flat then you'll probably get a whole bunch or error messages appearing, especially HDC faults and transmission faults. I've had this happen to me after playing the radio whilst washing the car (beginners mistake). I would charge the battery fully via a trickle charger. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #465831 Fri Jun 26 2015 5:12pm
DrRob
Get s ctek charger on it for 36 hours Thumbs Up Visitor from fullfatrr.com
Post #465838 Fri Jun 26 2015 5:50pm
wings21660
Flat Battery
Told the mechanic what you lads had said so he's lent me his trickle charger & it's on charge as i'me writing this. question he's asking will the codes need cleared after charging or do they just go off? Thumbs Up
Post #465896 Sat Jun 27 2015 2:18pm
wings21660
Tried the trickle charger, but the lights were still on. So the mechanic plugged his machine into the car & removed the fault codes, but they came back on before I left the garage. So if there is any person out there with another idea I will be willing to try before handing it to my local landrover dealership, all help will be much appreciated. The fault codes are UO132, UO159, UO416, UO421. Bow down
Post #466405 Fri Jul 03 2015 10:58am
Lost for Words
Start back at the basics; what voltages are you getting from the battery and alternator now? Thumbs Up Visiting from DISCO3.CO.UK
Post #466407 Fri Jul 03 2015 11:12am
garrycol
Australia
I doubt a trickle charger would do much as they are more for maintaining charge rather than charging.
You need a decent amp charger or preferably a smart charger - it will get a decent charge into the battery quickly and then repair and maintain plates - a trickle charger will not be able to deal with sulpherization (spelling) of the plates.
But a poor battery will through up faults all over the place - my battery is 8 years old on on the way out and it throws up low coolant faults all the time.
garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #466413 Fri Jul 03 2015 12:36pm
muddywheels
Milk Float Man
CTEK is good for maintenance but someone posted on here it will not recharge a flat battery Confused
About 10 years ago I flattened battery on a D2 letting kids watch LR fitted Dvd while parked. Had to get LR assist out - guy said driving would not recharge it so he jumped it then followed me to dealer who charged it overnight Shocked Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #466414 Fri Jul 03 2015 1:16pm
Lost for Words
I have found my MXS25 to be reluctant to charge a flat battery. I have found that it will normally be fine on the second attempt (I imagine because the battery has gained a little charge from the first). It's a cracking charger though and the reconditioning mode is great. Thumbs Up Visiting from DISCO3.CO.UK
Post #466415 Fri Jul 03 2015 1:20pm
wings21660
The mechanic finally got back to me with the voltage readings, with the engine switched on it was reading 14.88 & switched off reading 13.5, is that what you were after lost for words mate? Big Cry
Post #466720 Mon Jul 06 2015 5:18pm
DrRob
What fault codes on the reader has it brought up? Modern car problems are first diagnosed with a fault reader..... Visitor from fullfatrr.com
Post #466723 Mon Jul 06 2015 5:55pm
Both are high. Certainly the 13.5V must have been immediately after the engine was turned off - ideally you leave the battery to rest for several hours to find the true voltage. 12.7V is fully charged. The engine running figure is higher than one might expect unless either the battery is poor or the alternator is on its way out. 2012 SDV6 - it's missing a couple of cylinders
Post #466730 Mon Jul 06 2015 6:50pm
Lost for Words
As RRSTDV8 has said, the 13.5V reading from the battery must have been taken without leaving the battery for the surface charge to clear.
14.88V is perhaps a little high, but it could be expected with a poorer battery and isn't high enough to cause problems in it's own right.
As an accurate standing charge reading from a 12V battery, this is what you're looking for:
Post #466814 Tue Jul 07 2015 1:52pm
wings21660
Dr Rob the only fault codes I was given is the ones i posted earlier hope this helps Thumbs Up
Post #466826 Tue Jul 07 2015 3:49pm
steve2026
2005 Range Rover Sport Supercharged Vesuvius Orange
Always handy to have a powerpack handy for all those blowing up of airbeds type of job, also comes in handy for charging phones and things, as well as jump starting cars with dead batteries.
Did I mention I am selling one, must have slipped my mind, lol. 2005 Vesuvius 1st edition ( now sadly gone ).
Post #466969 Wed Jul 08 2015 5:59pm
