![]() | Home > Maintenance & Modifications > Gearbox flush in south wales. has anyone done it! |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4421 ![]() ![]() ![]() |
Mine also has an incorrect gear ratio fault, occasionally 4th gear, more frequently in 5th gear.
Williamsboy Member Since: 31 Dec 2014 Location: south wales Posts: 44 ![]() ![]() ![]() |
Hi Disco
Hamner Member Since: 28 Jan 2015 Location: Swansea Posts: 54 ![]() ![]() |
hi mike , real sorry to hear that i wish you the best of luck with it regards danny |
I believe Bristol Transmissions are quite highly regarded on here. ![]()
Make sure you stop using it before it's too late. Probably just needs an adjustment. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
RogerDeFlor Member Since: 28 Mar 2015 Location: Gloucester Posts: 51 ![]() ![]() ![]() |
Adjust the shoes, as per Bodsy's Brake Bible, that'll save you at least a few shekels. If you've not done it before, don't worry, it's quite easy to do when you get down to it. ![]() |
Hi guys noticed something odd on my way home from work. Parked on the drive rrs in normal suspension mode, engaged epb and had the actuator / epb squeel/ screech. Dis engaged epb and lowered to access level, re-engaged epb with no screech/squeeling noise. Raised the suspension and tried again and applied epb to be met by the screech/squeeling noise. Lowered rrrs and no noise when epb engaged.
The EPB screech won't be a wiring fault. What you're seeing is probably related to the change in geometry when lowering the car. |
Cheers lost for words. Just thought it was a bit odd that's all.
hi guys , just doing some more research on amega flush does anyone know what difference the zf fluid makes as to other transmission fluids as there is a lot of difference in cost cheers |
Using the correct fluid is certainly very important. It's not something I'd take any risks with. |
Hi all just an update on the gearbox issues. Towed the tin can to the gower this week and transmission fault happened on four occasions. Did exactly the same on the way home a few days later. RRS going in tomorrow for gearbox strip |
Did you get it sorted? Visitor from fullfatrr.com
Hi DrRob, RRs is in the Garage with the Gearbox dismantled. Box is Knackered! the garage have sourced a Reconditioned Gearbox with 2yrs unlimited mileage warranty for me. so not sorted as yet but on the right road.
