Home > General (L494) > Live Ignition Feed |
GTF Member Since: 24 Jun 2015 Location: Aberdeen Posts: 7 |
Hi does anyone know where to find an ignition feed inside the cabin - I want to fit a dash cam ? |
Wed Jun 24 2015 7:58am |
really.......? I'm not sure how cutting off the end of the plug and wiring it to the back of the socket would be different from plugging the socket into the ign switched socket? both deliver the same voltage.... You CAN get a battery monitoring box that will stop the Dashcam from working when the voltage is too low, but if only running Ign switched live, it shouldn't be a problem. Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
Wed Jun 24 2015 9:25am |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
In mine the cigar plug reduces the voltage to 5v so cutting the plug off may not be a good idea MY16 AUTOBIOGRAPHY Indus silver with some toys
Wed Jun 24 2015 12:06pm |
thats a fair point I would hope voltage has been checked first Bodsys Brake Bible
Wed Jun 24 2015 12:07pm |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
Thats right, its the plug not the socket that reduces the voltage to 5v. Thats why there is a hard wiring kit on the market,that has a reducer in the wiring itisme |
Thu Jun 25 2015 7:30am |
Garage Door Medic Member Since: 02 Feb 2014 Location: North West of UK Posts: 197 |
There is a switched live feed up in the overhead console, I bought a hardwired kit for mine, and it comes on as soon as I get in and goes off when I lock it up, there is a very good post on here, step by step of how to wire it, took 15 mins in total and worked 1st time MY 13 3.0 SDV6 HSE Black Edition
Thu Jun 25 2015 8:22pm |
Have a look at this
Thu Jun 25 2015 8:27pm |
