Home > Maintenance & Modifications > Auto gearbox flush |
rrsrad Member Since: 05 Feb 2015 Location: Cheshire Posts: 36 |
I also would be interested in a gearbox flush, could nip up to manchester or somewhere convenient Range Rover Sport 2010 3.6TDV8 HSE Santorini Black |
Sun May 31 2015 6:35pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Flat out just now guys, but will make a plan in a week or so, and reply to PMs then |
Sun May 31 2015 7:42pm |
Toe Member Since: 26 May 2015 Location: Cheshire Posts: 4 |
Test |
Tue Jun 02 2015 1:34am |
Steveo Member Since: 12 Dec 2014 Location: Shrewsbury Posts: 12 |
Hi all, is there anywhere in the Shropshire area that carries out this work as I'd like to get mine flushed, my rrs sometimes doesn't like going into 6th gear unless you put your foot down after 60 mph,, would the flush help this at all or have I got another problem? |
Tue Jun 23 2015 10:34am |
hi thanks for your response, as an example I have a 8mile drive to work in the morning 3 miles on country roads then a 6mile straight run up the a5, monday morning it changes fine going into 6th at just over 55 mph then Tuesday I'm going up the a5 at 70mph and it's still in 5th gear and will stay in 5th unless I put my foot down quick then pull off and it will change, there's no vibration or odd noises so was hoping the gearbox flush might help |
Tue Jun 23 2015 12:27pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
With only a short drive, what you're seeing could be that the box has not got up to temperature so won't go into 6th. Have you noticed it on longer drives? Visiting from DISCO3.CO.UK
Tue Jun 23 2015 12:35pm |
^ ^ pretty much what I was thinking. Been doing some live data logging recently and the engine temperature doesn't hit fully warm until driven about 12-15 miles with all but the first couple on motorway at 70 mph. You are presumably talking about behaviour in 'normal' and not 'Sport mode? 2008 MY Java Black TDV8 HSE |
Tue Jun 23 2015 12:57pm |
Yeah in normal mode not sport lol
Tue Jun 23 2015 1:44pm |
From the 1st page |
Tue Jun 23 2015 2:13pm |
^^^ There you go. A Disco_Mikey megaflush, gearbox reset ECU reflash and the added benefit of his diagnostic expertise should see you sorted. 2008 MY Java Black TDV8 HSE
Tue Jun 23 2015 2:33pm |
peterk Member Since: 17 Nov 2014 Location: Blackpool Posts: 10 |
Had the gearbox flushed thanks to disco Mikey, all sorted now and the car shift seems smoother.
Sun Jul 12 2015 7:51pm |
